| Home > Help Needed / General Tech Chat > Exhaust manifold - damaged? | |||||||
90 Posts Member #: 10229 Advanced Member Stroud |
16th Feb, 2014 at 10:18:40pm
Ive got a standard t3 cast iron exhaust manifold with what appears to be a common problem. The two dividers that face the turbine housing are well, a little crap. Im worried that with more heat and more use that they will crack and potentially crumble off into my turbo. Is it safe to just grind these two back to prevent this?
16th Feb, 2014 at 10:30:25pm
Yeah grind them back to good metal. On 28th Aug, 2011 Kean said:
17th Feb, 2014 at 10:14:27pm
yes as joe says chris, job done
17th Feb, 2014 at 10:36:35pm
Is it ok to completely do away with them then? As in, just grind them right away? That wouldnt have an adverse effect on the turbo would it? |
17th Feb, 2014 at 10:59:20pm
cut it back but as minimal as possible as it relies on pulse from exhaust to spool the T3 up.
20th Feb, 2014 at 10:56:45pm
Does anyone have any photos of what it should look like once cut back? Im a little nervous at cutting them back now :( |
20th Feb, 2014 at 11:36:03pm
Have a look here on this manifold I did. You can see how they can be cut back.
21st Feb, 2014 at 02:04:30pm
Thanks, where can i find your manifold There was no link in your post. |
21st Feb, 2014 at 07:41:36pm
Ooooops ! http://www.turbominis.co.uk/forums/index.php?p=vt&tid=9465
21st Feb, 2014 at 11:32:15pm
Briiliant! Thanks. Obviously doesnt require much grinding back then?! |
22nd Feb, 2014 at 09:07:15am
When I ground out the GT1752 to suit the Metro manifold I needed to cut back the dividers more than that as I visualised the flow being restricted unless I did.
