Home > Help Needed / General Tech Chat > ERA Mini - Valve Stem Oil Seals
ricsdad
Member #: 9406
Tadley, Hampshire.
Recently purchased a "Standard" ERA Mini - British spec. It has not run in a while so having checked that it would run - which it did - and didn't smoke - I decided to do "The right thing" and have the head off, renew the headgasket and change the valve stem oil seals.
Please can you advise me on the following:
Having taken the head off I find that it has Double valve springs on the inlets with the normal valve stem oil seal fitted to the top of the valve guide. Spring dimensions are Large: 44mm long 28.8 dia 5 full coils Small: 42mm long 20.4mm dia 6 full coils.
On the exhaust it has the correct valves marked TAM1330 and SINGLE VALVE SPRINGS 51.25 long 29mm dia 5 full coils. The interesting bit is it is fitted with LUB10009 valve stem seals which are normally used on a Land Rover Discovery 2.0l T16. It is impossible to fit the smaller second internal spring with these seals as the seal is bonded into a steel "hat"onto which the valve spring sits thus preventing the seal from rising.
I have read somewhere on Turbo Minis about a modified valve stem oil seal - but also recall that the company making/distributing them is no longer trading.
So the specific advice I would like is:
A) Refit as it was with double inlet springs and 4 traditional valve stem oil seals and leave the single springs on the exhaust but renew the LUB1009 Should I also replace the valve springs with a known value - if so which ones?
B) Return it to standard by fitting the correct lower locating collar, double valve springs and 4 traditional valve stem oil seal. (I do have these parts available)
C) Any other suggestions - given that it is an ERA and more for show than go! Running on 4 cylinders and not smoking with a bit of Turbo whistle will suit me fine!
It has standard rockers.
I wouldn't run exhaust seals on a turbo. Fit only on inlets.
in short here are the good guy seals you want https://www.minispares.com/product/Classic/...oduct.aspx|Back to
and the double valve springs if its a standard motor https://www.minispares.com/product/Classic/.../classic/double valve springs.aspx|Back to search
I disagree. We fitted decent ones on the metro van and they caused.no ill effect at 25+ psi.
this^^^^^
steve ,
are those seals soft ,with no steel in them? I used some steel bodied one on mine and I have no idea what they are really made for originally, just had them in my parts bin . .
Robert, those seals are top quality, never go hard and exception. Wear tolerance, I fit them to all my heads with inner spring retainers to stop the inner spring poping the seal off,
I concur. With Andy Bellamy totally. !!! V
metroturbo
Member #: 989
North Yorkshire
This thread may be of use if you want stem seals for the original 8mm exhaust valves http://www.turbominis.co.uk/forums/index.php?p=vt&tid=552271
