Home > General Chat > Turbo manifolds
Ryancarlin1
Member #: 11056
South yorkshire
How many of you have used side mounted turbo manifolds? Just want to see some pictures and also where the turbo will sit, there won't be enough room for the brake servo, shall I use a remote servo or not use one at all? What do you think is best?
jonny f
Member #: 9894
Dorking
Don't use a servo. not many people on here use them anyway and its good weight saving.
Search remote manifold or side mount
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
prefer to have to push the peddle a bit more and feel the brakes work
found it harder with a booster when throwing the car around or coming into a bumpy corner when pushing the cars limits
not really running or using the side mount turbo as yet but its running
theirs a bunch of pics up in my show us yours not saying that mine is the right way or the way to do it as ive not finished the car and not been boosting around on it yet
however its my idea on a side mount that i think should work that said i would do things a bit differently next time live and learn...
my set up is a task to assemble to say the least its worth the time to figure out ways to make it all work so it can be easily assembled
The only advantage to a sidemount (in my eyes) is to be able to build a manifold like Paul's. If you're not going into that much detail, then you might as well stick it down the back of the engine.
It's better for weight distribution and CoG for a start. And in your case it means you don't have to think about the brakes.
Some discussion here as well:
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=550197
My simulations show that there is potentially an extra 5-10% more power available if done correctly i.e. using the right length and diameter pipes. Even more if mated up with a tuned length inlet.
The first mod to any standard NA mini is to junk the cast iron exhaust manifold. I think that the Metro turbo exhaust manifold should be regarded in exactly the same way. It was designed for packaging with no regard to the effect on performance. In fact the science behind performance manifolds was little understood and rarely implemented back in the 80s.
I'm currently collecting bits to make one out of an MPi exhaust manifold.
wolfie29177
Member #: 476
The Black Countraaaaay
if you've got Vizards bible there's a picture of the Janspeed setup in there
Masturbation is not a crime its a hobby
Yes, the Janspeed setup is a good example of how not to do it *smiley*
Runner length is critical.
danb41
Member #: 9285
Oxfordshire
Whats the ideal runner lengths and pipe I/D to use Paul?
As a general guide, the closest you can get to the LCB dimensions the better. The pulses are still there to be used on a turbo motor just the same as NA, only the amplitude is much bigger and therefore can be used to great effect.
The yellow bible gives ideal LCB dimensions for large and small bore motors.
This is definitely not a case of the bigger the better. Too large a pipe and you lose the pulses. Too short a pipe and they come back too quick.
