| Home > Help Needed / General Tech Chat > Car running fine dump valve not working | |||||||
7 Posts Member #: 11739 Junior Member |
14th Apr, 2018 at 07:10:14am
Hi just been driving about in mini with metro turbo and noticed dump valve not working. Have changed for new one, but still nothing. Have connected boost gauge which reads nothing. Car definitely comes on boost and goes well and lots of noise from wastgate when changing gear? Any ideas thanks |
257 Posts Member #: 11017 Senior Member Shropshire |
14th Apr, 2018 at 07:44:51am
Where's the sensor line plugged into? |
![]() 2975 Posts Member #: 10749 Post Whore lowestoft suffolk |
14th Apr, 2018 at 11:02:38am
Was it working before? On 24th Oct, 2015 jonny f said:
Nothing gets past Dave lol NOTHING GETS PAST ME!!
1/4 mile 14.7 @ 96mph 12psi boost Showdown class A 2nd place 18.6 @ 69mph |
15th Apr, 2018 at 08:07:56am
Was working before, it is on the side of the plenum chamber on the left, and the boost gauge is connected on the other side drilled into the plenum as well? Drove to the pub yesterday with three blokes and pulls well but the dump valve? |
15th Apr, 2018 at 09:12:25am
For an accurate reading the boost gauge should be connected into the inlet manifold. The small end of the dump valve also needs taking to the inlet manifold to.
15th Apr, 2018 at 10:07:36am
Cool, do you have a diagram please? Thanks again |
976 Posts Member #: 3228 Post Whore North of the Netherlands |
15th Apr, 2018 at 11:36:47am
Using search:
Dazed and Confused.... |
15th Apr, 2018 at 12:24:34pm
This is very very simple.
15th Apr, 2018 at 02:10:46pm
Do you a picture of where I should connect boost gauge thanks |
15th Apr, 2018 at 06:32:58pm
No.
15th Apr, 2018 at 06:42:04pm
On 15th Apr, 2018 Farrierman said:
Do you a picture of where I should connect boost gauge thanks The inlet manifold. Drill and tap for 1/8 BSP, screw in a suitable hose tail and connect the pipe from the boost gauge to this. Simples !! Phil. |
15th Apr, 2018 at 07:13:29pm
Just to make sure we’re on the same page, you obviously need to remove the inlet manifold before drilling and tapping it... On 17th Nov, 2014 Tom Fenton said:
16th Apr, 2018 at 06:49:57am
Or take out the banjo bolt for the servo pipe and drill that. In the 13's at last!.. Just |
![]() 608 Posts Member #: 1106 Post Whore Hungerford, Berks |
16th Apr, 2018 at 07:30:54am
Here you go:
’77 Clubman build thread
16th Apr, 2018 at 10:31:42am
Thanks great help |
16th Apr, 2018 at 03:34:06pm
As already mentioned the signal line for the dump valve needs to be plumbed into the inlet manifold not the plenum. They work on the principle that what the throttle is closed one side of the dump valve is subjected to less air pressure that the other allowing the piston to move. With both sides connected to the plenum they will always be at the same pressure and nothing will happen.
16th Apr, 2018 at 06:34:36pm
And if the DV is slow in operation, usually delayed, or giving a long dumping sound, you’ll need to replace the butterfly in the carb with a solid one that doesn’t have the poppet valve installed (or remove the valve and solder up the holes)... On 17th Nov, 2014 Tom Fenton said:
