| Home > A-Series EFI / Injection > Baffled tank or swirl pot | |||||||
10 Posts Member #: 11981 Member |
13th Apr, 2020 at 11:59:30am
My first post! Afternoon all. I have chosen to go 7 port and injection so need to fit high pressure pump.
2646 Posts Member #: 1246 Post Whore Lowestoft, Suffolk. |
13th Apr, 2020 at 12:45:09pm
welcome.
13th Apr, 2020 at 12:50:47pm
It's a pick up not saloon
Edited by IronmanG on 13th Apr, 2020. |
13th Apr, 2020 at 01:25:52pm
Sorry I missed that bit totally.
Edited by shane on 13th Apr, 2020. |
13th Apr, 2020 at 01:32:03pm
How much space is above the top of the tank when it's installed?
13th Apr, 2020 at 02:30:07pm
Not much. It's pretty snug.
13th Apr, 2020 at 08:07:01pm
It can't be gravity fed on a lwb tank because the pickup is the middle of the tank half way up. The lwb tank can suffer from starvation on sweeping bends etc. I have fitted a swirl pot and 2 pumps after recommendations on here |
13th Apr, 2020 at 09:00:23pm
Just a side thought, I remember reading recently in PPC magazine, one of the contributors has a Scimitar with an Omega engine in. I believed it ran a MK2 golf pump as it was a neat self contained unit/ separate small tank which did all he needed to run the EFI. I may be wrong on the detail as it was a few months back.
13th Apr, 2020 at 11:06:34pm
An old Golf Bosch pump is the same as the Metro turbo ( and many others ) fuel pump.
14th Apr, 2020 at 07:10:19am
Do you have some pictures please?
14th Apr, 2020 at 07:58:23am
On 14th Apr, 2020 IronmanG said:
Do you have some pictures please? On 13th Apr, 2020 hazpalmer said: It can't be gravity fed on a lwb tank because the pickup is the middle of the tank half way up. The lwb tank can suffer from starvation on sweeping bends etc. I have fitted a swirl pot and 2 pumps after recommendations on here https://www.instagram.com/p/B7JEQlIjTdE/?ut...g_web_copy_link best i can do at the moment. Mine isnt as neat as it could be i think. Swirl pot is mounted on that panel that is pop rivited in. I then drill holes through that and the lower boot floor fitted grommets to run the house through. The lift pump and filter is on the rear subframe like it would be if it was gravity fed on a normal saloon. The lift pump is mounted on the back of the rear subframe on a metal plate near where the fuel union is on the tank. The return from the swirl pot is T'd into the low pressure side between the lift pump and the tank. Its a lot of fuel hose because of the different size fittings on the tank, filters etc. I havent used this set up yet, but i thought it was best to do it this way. I have heard people just using a normal efi pump but i didnt want to take the chance. |
14th Apr, 2020 at 08:22:44am
half way down the post, appreciate its a saloon but the theory is the same.
14th Apr, 2020 at 10:10:27am
I’d modify the tank for an internal pump and plate. It’s not difficult and makes for a cheap, simple, quiet setup with lots of pump options. In the 13's at last!.. Just |
14th Apr, 2020 at 11:40:51am
On 14th Apr, 2020 theoneeyedlizard said:
I’d modify the tank for an internal pump and plate. It’s not difficult and makes for a cheap, simple, quiet setup with lots of pump options. This would be my preference I think but on a pick up tank? Is there enough room and still baffle the tank out? |
14th Apr, 2020 at 12:47:05pm
14th Apr, 2020 at 01:27:28pm
Ye just been having a think. I reckon weld some aluminium plate in to the tank about 3 inches high 5 inch diameter. Drop the pump into it. Couple of small holes allow fuel out and minimise sloshing. An mpi pump with the return. Even weld an extra bit on the tank so it protrudes slightly below the normal level
14th Apr, 2020 at 08:38:00pm
https://www.motorsport-tools.com/catalogsea...esult/?q=walbro
186 Posts Member #: 7637 Advanced Member Fremont California |
14th Apr, 2020 at 10:35:22pm
This is what Nick Upton of Woodland California did for us that we use in our wagon.
Edited by tmsmini on 14th Apr, 2020. |
15th Apr, 2020 at 06:47:58am
Very neat indeed. Thanks for the pictures |
15th Apr, 2020 at 07:43:23am
I'm sure I've seen a picture on here of someone doing similar, with a neat oval shaped access port in the side of the tank, to accept an in tank pump. Can't find it though.
15th Apr, 2020 at 04:32:08pm
This might be the one Tom is referring to:
15th Apr, 2020 at 06:35:04pm
Interesting that. Thankyou |
15th Apr, 2020 at 06:35:07pm
15th Apr, 2020 at 10:53:57pm
On 15th Apr, 2020 tmsmini said:
This might be the one Tom is referring to: http://www.stallard-engineering.co.uk/stor...he_fuelling.htm http://www.stallard-engineering.co.uk/stor...he_fuelling.htm Maybe I'm missing it....but there I see absolutely no attempt to combat fuel slosh there ? All he's done is adapt an in-tank pump, into the same inappropriate design of tank for EFI. And the wiring pass through looks questionable. Unless the car is only ever going to cruise along in a straight line, it will need good baffling in the tank or the likes of the Holley hydramat I mentioned. Modifying the tank for an in-tank pump itself is pretty easy if you can weld or braze, but in order to properly baffle it....the tank would need to be opened up quite a bit to allow the work to take place. Or space permitting, an additional sump type feature might be able to be added somewhere as a half way house. 9.85 @ 145mph
15th Apr, 2020 at 11:50:22pm
Ours is in a little box that acts as a baffle and seems to be working well enough.
