Home > Help Needed / General Tech Chat > Metro/Mini inner cv/pot joint differences?
I’ve just discovered a brand new set of pot joints while tidying out a cupboard in the workshop.
They’re labelled as “Rover Austin Metro”. I seem to recall there’s some difference between these and the Mini ones, anybody know?
I’ll keep them if they’re useable otherwise they’re for sale.
Phil.
shane
Member #: 1246
Lowestoft, Suffolk.
I've a metro and a mini engine in the garage with the pots in the box still, I can have a look tomorrow and see if there is anything obvious.
Shane
Cheers mate.
Phil.
metroturbo
Member #: 989
North Yorkshire
There is a bit of info here that might help.
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=442031
Jd24-7
Member #: 11761
Worcestershire
I have mixed and matched and never noticed a difference. Drive shafts are obviously different in length, but otherwise similar. My 998 is stock from a late model mini with its inners, running metro outers. The older 1275 was straight out of a metro, from a pick your own scrap yard, so I would have taken everything that could be seen as part of the engine and box *smiley* . There might be internal differences or improvements, but I can't see rover not using what was already in the parts bin. (Unless someone decided to metricate them!!!!)
Over the years, Ive swapped mini shafts onto metro inners and outers and old austin 1100 outers with hubs and they all seem to have compatible splines
Do they have rubber Gaitors that don't dissolve in natural air??? They could be like gold dust *smiley*
Jd
Jd24-7
Member #: 11761
Worcestershire
Jd
Cheers for the replies. The boots must be good quality as I’ve had the joints for 20+ years and the rubber hadn’t dissolved yet.
Phil.
From memory, when I sent a set of shafts over to the USA (as per the thread linked earlier) the pot joints themselves are essentially the same.
The splines that engage in the diff and the internal splines for the drive shaft are definitely the same.
The internal bits may be slightly better, the balls and cage looked slightly larger (but what I was looking at may have been a re-conditioned pair where they re-grind the grooves and use larger balls).
The main difference is obviously the shaft length, BUT, also the way the boot fits.
The Metro boot is much longer (and way superior) so the locating "groove" for the metal clip (or cable tie if you do it on the cheap) in the metro shaft is further out.
So, on a Mini, you have to use the cheap/nasty Mini inner boot, not the better metro one.
EDIT 2
The other thing to consider is whether the Metro boots would actually fit inside the holes in a Mini subframe ?
Edited by Rod S on 23rd Jan, 2021.
shane
Member #: 1246
Lowestoft, Suffolk.
I dug out what I had in the garage this afternoon but the Metro joints I've got have no inners to provide complete comparison.
I've checked over the outers and the only difference (as mentioned above) is the type and retention groove for the CV boot.
Internal measurements appear to be the same but I am comparing a 40k mile metro pot to an unknown millage mini one.
Images below; Mini pot is on the left and Metro on the right.
Sorry I couldn't be more help.
Shane
Edited by shane on 23rd Jan, 2021.
Thanks for that Shane, top effort.
Phil.
graemec
Member #: 1424
Carnforth, Lancs
Phil,
There were some Metro 'heavy duty' ones which are what Rod is describing I think, these aren't that common. The Metro did also use one the same as the Mini.
The heavy duty Metro ones are like this:
If the ones you have 'found' are like these then I would gladly buy them from you - I use them on my rally car.
Edited by graemec on 9th Feb, 2021.
These are the ones I have on the mk1, they are sealed (boot is on a tube) and made by hardy spicer.
On 9th Feb, 2021 graemec said:
Phil,
viz139
Member #: 9182
There are two sizes.Years ago when doing a swap I had inners two big for the outers. Can't remember the source of the parts but had to use them as matched sets.The big problem would be if you put a small inner in a big outer and didn't notice.
viz139
Member #: 9182
I found two of the odd CV in the workshop today.As per Shanes photo the difference on the outside is the width of the boot retainer ring.The difference in the outer part is the thickness of the wall between the ball bearings. The difference in the inner is the external diameter of the cage. Big cage will only fit thin wall but small cage will fit both.
viz139
Member #: 9182
Photo of large cage sitting on thickwall outer. The thicker wall would increase the contact area with the ball bearing
