| Home > Help Needed / General Tech Chat > Intercooler ideas | |||||||
83 Posts Member #: 12240 Advanced Member Kent |
15th Jan, 2024 at 10:50:50pm
Hi I'm looking at what intercooler to fit to my round nose front mini with side mounted turbo.
15th Jan, 2024 at 10:51:18pm
16th Jan, 2024 at 12:25:23am
Escort RS Turbo Own the day
16th Jan, 2024 at 10:00:46am
On 16th Jan, 2024 Mr Joshua said:
Escort RS Turbo What one? It looks like there are a couple of different ones |
2646 Posts Member #: 1246 Post Whore Lowestoft, Suffolk. |
16th Jan, 2024 at 10:46:02pm
Series two, has plastic end tanks that has brackets that you can trim off to slim it down, it fits nicely at an angle over the clutch housing.
Edited by shane on 16th Jan, 2024. |
Site Admin 6301 Posts Member #: 1 The boring bloke who runs this place. Berkshire |
17th Jan, 2024 at 10:48:41am
I use a cossie one, from a 2wd cossie I think.
17th Jan, 2024 at 06:12:51pm
On 16th Jan, 2024 shane said:
Series two, has plastic end tanks that has brackets that you can trim off to slim it down, it fits nicely at an angle over the clutch housing. http://www.turbominis.co.uk/forums/index.php?p=vt&tid=588553 There is a post on here that shows a neat tidy install of one but I'll be buggered if I can find it. Cheers mine has a side mount turbo so there is no space what so ever around the clutch housing http://www.turbominis.co.uk/forums/index.php?p=vt&tid=2325 Found it but images no longer work. I have a picture of one installed in my car circa 2008 but I can't upload it. Shane |
17th Jan, 2024 at 06:16:30pm
On 17th Jan, 2024 AlexB said:
I use a cossie one, from a 2wd cossie I think. I have found people using them but they are long so the will not fit at the front. unless I front mount it under the bumper |
17th Jan, 2024 at 10:11:29pm
The 2wd Cossie one does fit but is snug from memory, I think Starmag / Ron used to run one (I may be wrong) I seem to recall his bonnet had a bulge and was raised at the rear to assist with clearance?
Edited by shane on 17th Jan, 2024. |
18th Jan, 2024 at 10:26:46am
Yeah it does fit.
18th Jan, 2024 at 12:49:46pm
On 17th Jan, 2024 shane said:
The 2wd Cossie one does fit but is snug from memory, I think Starmag / Ron used to run one (I may be wrong) I seem to recall his bonnet had a bulge and was raised at the rear to assist with clearance? The 4wd cooler is a larger unit Pace made an uprated unit for the R5 turbo which I managed to squeeze in the front of my old Minus, it was snug tho. Don't rule out a cooler which the core will fit but has incorrect sized or facing end tanks, you can always fabricate your own. Nissan 220SX S14 OEM cooler has a square core that fits in the front but would need new end tanks. Failing that have a chat with Bob and Clare at Concept Racing, a very helpful pair and their work is first rate. Shane Thanks |
18th Jan, 2024 at 12:54:06pm
On 18th Jan, 2024 AlexB said:
Yeah it does fit. ![]() Thanks I'll look in to that..have you put holes in the bonnet for air flow? |
18th Jan, 2024 at 04:36:50pm
Yep, along the front. had to modify the end-cap outlet too. |
