| Home > Technical Chat > Inlet Manifolds - MG | |||||||
809 Posts Member #: 224 Post Whore Katy TEXAS |
8th Nov, 2005 at 05:06:59pm
Is there any reason why you can't use a non turbo alloy inlet manifold in conjuction with a turbo ? BTW - I took my buddy VTEC Pete out for a spin this weekend, and even though I am running her in, he gave it a name, the "Brocket"...cause I'm a brocket maaannn, nah nah nah nah nah nah nah nah nah nah nah....
8th Nov, 2005 at 05:17:47pm
im running a n/a mg metro manifold on my car, and it seems to be doing fine, however im not running the std exhaust manifold so i cant tell you wheter it fit with it |
8th Nov, 2005 at 06:53:06pm
Thanks Nic
Edited by Brocky on 8th Nov, 2005. BTW - I took my buddy VTEC Pete out for a spin this weekend, and even though I am running her in, he gave it a name, the "Brocket"...cause I'm a brocket maaannn, nah nah nah nah nah nah nah nah nah nah nah....
8th Nov, 2005 at 07:33:46pm
the mg N/A manifold flows slightly better than the turbo manifold as fast Carl & turbo dave found on the flow bench.
9th Nov, 2005 at 12:00:23am
On 08/11/2005 17:06:59 Brocky said:
Is there any reason why you can't use a non turbo alloy inlet manifold in conjuction with a turbo ? I guess the shape of the original owes to an even pressure distrubution across the ports but would I cause any damage ? the mg manifold positions the carb rather close to the turbo exhaust manifold the mounting flanges are a lot thinner than the exhuast ones,so you need to make some stepped washers to hold it on
9th Nov, 2005 at 12:13:54am
It is not so much pressure distribution, but mixture distribution.
9th Nov, 2005 at 09:00:28am
Thanks Tom
10th Nov, 2005 at 10:08:55am
also its a damn site easier to fit and remove than the NA manifold as you can get to the nuts.
