Home > Show Us Yours! > GAS FUMES INSIDE CAR
dboatman
Member #: 744
Seattle, Washington, USA
Third time trying to get a response, topic doesn't stay on. I have a 1961 Austin with a punched 1275 w/turbo. Cabin has strong gas fumes, gas tank has no vent, however cap is vented. I even tried running with the cap off-no better. As the fuel is returned to the tank, it creates fumes inside the car.....any cures? Do I need to get a tank with a vent? Dan
dboatman
Member #: 744
Let me know.
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=6838
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=6819
You clearly need to do some more research. And to stop posting in the wrongf section.
and another one.
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=6571
I'm not sure what you're doing, but if you click the icon at the top that says 'Home' then you're looking at all the sections you could post in.
'Show us yours' says "Post pictures in here.." next to it. You have asked your question every time in this section. in case you haven't realised, this is where you show pictures of your mini.
You would be best posting in the
' Help Needed - Ask your mini related questions here'
section...
All Mods - we'll leave this in this section just this once please... *wink*
Dangerous
Member #: 417
Just click on your own name
Topic Name Forum Date
GAS FUMES INSIDE CAR Show Us Yours! 26/11/2005 21:18:10
GAS FUMES IN MKI Help Needed 23/11/2005 21:06:37
GAS SMELL INSIDE CAR Help Needed 22/11/2005 00:48:24
NEW TURBO OWNER, NEEDS HELP! Help Needed 02/11/2005 20:24:24
NEW TURBO OWNER. HELP NEEDED. Help Needed 02/11/2005 21:45:33
Edited by Dangerous on 27th Nov, 2005.
dboatman
Member #: 744
I'll look for the vent again. However, i think it's being used as a return. I can hear gas running back into the tank when key is on and electric fuel pump is running. Dan
The vent is slap-bang in the middle of the tank at the top. It's not easy to use it as a return becuase you need a 8mm minimum return... The vent is less than half that diameter.
My thoughts are that if the vent is blocked, running the tank with the cap off did not improve matters, you need to look somewhere else for the source of the smell/leak.
However, if the vent is open into the boot, you will continue to get this smell until you route a pipe from it out under the car.
t3gav
Member #: 229
Gavin@minispares.com
kent
how about please? i've asked questions before and got no reply the same as everyone else, advice is free and mostly to a brilliant standard better than you can find anywhere else, everyone is also friendly and will go way out of their way to help when they could be in the pub, just pays to be a bit more courteous, gav
dboatman
Member #: 744
Thank you for the advise. May have not looked hard enough for the vent tube. I'll have a more through look. Sorry about the "no please". As far as the drinking in the bar goes, any of you mini-guys find your way to Seattle.....I"M BUY"N!!!!! Dan
Yeah - a picture or two. Maybe of the wife, or the dog taking a nap in front of the fire, or of a nice landscape?
Your choice.
*laughing* *laughing* *laughing* *laughing* *laughing* *laughing* *laughing* *laughing* *laughing* *laughing* *laughing* *laughing* *laughing* *laughing* *laughing* *laughing*
Zeemax Power
Member #: 393
Oulton Park
Read what you lads have put but i still can't work out why i get it there no leaks in the tank and i'm using the same fuel lines that came off my spi mini but the stink of fuel is strong i have ran a pipe of the brever twice the size and ran that out to the under of the car but i have a diferent fuel cap that doesn't left air out but i have even sealed that up and still smell fuel work it out i can not any ideas
http://www.Zeemax.com
On 28/11/2005 23:44:26 mini1071s said:
Well this is my fire.
Fuck me Pete, think you need to invest in a Sprit Level...
