Home > Wanted > charade alternaTor
Carl
Member #: 95
liverpool-on-sea
im after one of the above if anyones got one obviously in good condition.
does any one know if a charade gti alternators the same as the normal small one?
thanks
antman
Member #: 358
Snetterton, Norfolk
you will be very lucky if you can find a charade gtti alterator!! they are like rocking horse excrement!!!
I think that Nic fitted a small alternator on his from a less rare Suzuki Swift and it went on quite easily if i remember him correctly (it was last summer!!!).
im charade
it was easy only some machining (hacksaw and file ahem) required, and wiring is easy peasy
Carl
Member #: 95
liverpool-on-sea
i can find an charade gti alternator but dont know if its small like a normal charde one*smiley*
I'm pretty sure it is...
Dangerous
Member #: 417
Heres a gtttiii one,can't remember if it's the same
http://i3.ebayimg.com/01/i/05/5a/21/01_1_b.JPG
looks the same on that pic, ill have a look at mine tomorrow and look for a pert no
heres a pic of mine
there are a few no.s on it, but i think this is the part no 2706087701
Carl
Member #: 95
liverpool-on-sea
cheers nic
If it is a lightweight alternator youre looking for, i should be stocking very light 40 amp units shortly and very cheap. If youre interested ill update you with this.
Paul
Carl
Member #: 95
liverpool-on-sea
it was more space saving than light weight. im sticking to side rad at moment so dont need a charade alternater unless one pops up.
id still post details of your light weight one as it wiill be of interest of people probably.
paul-can you get lightweight starters? mine is creamy muck mucked and i need a new one, could be a chance to upgrade
The alternators are very small, which is why theyre light.
I am on the case for starters at the moment. Hopefully ill be stocking both in January.
Paul
Tweekies stock a lightweight starter for the a-series (around £200). they weigh 2.5kgs.
A standard (late type pre-engaged) one weighs 3.5kgs.
Wil
nutter driver
Member #: 47
Not very sunny swanage
sounds like a bloody expensive way to save 1kg! not having any breakfast before you race would probably have the same effect!!! lol!!!
indeed!
That was my point. Too much money for 1kg.
Dangerous
Member #: 417
But if it is 1kg off the rotating mass,Then at approx 20,000+ rpm It will be quite a bit of wieght
Bu I was talking startermotors.
Wil
Mine should be a lot cheaper than that, otherwise i wont even bother with them.
Paul
keep us posted paul
Stig
Member #: 694
Shropshire
I like the sound of the alternator then i could sort out the front mounted rad *smiley*. However pics of both would be excellent when you get them in stock paul.
No probs (i hope)
Paul
You could try one from the Suzuki SJ jeep range. I got one for a very steep £10 *surprised* off Fleebay....... Looks just like the one in the picture!
Gavin. :)
