Home > Wanted > Heater Hoses Wanted
As title, I want the heater hoses as fitted to the later 998cc minis, maybe 1989 onwards at a guess?
They are 5/8" bore, one comes out of the bottom hose, the other comes out of the cyl head take off at the clutch end, and is moulded with a 90 deg bend in it, comes across the front of the rocker cover and then sweeps back toward the bulkhead.
I have tried plumbing it in straight 5/8" heater pipe and it looks gash, so I need the proper hoses I think.
Ta
Tom.
Andymini
Member #: 438
London
Tom,
How about making an elbow that bolts onto the cylinder head?
I could do, but I would then need to make other elbows further down the pipe to take it round the stat housing etc. One of my pet hates are pipes with loads of joints in, so I'd like to use the one already moulded to do the job if poss.....
Sorry Tom I haven't got any, but I thought this link may help in the identification process?http://www.minimania.com/images/FicheCatal...es/90_2_F10.htm *wink*
Gavin. :)
Yes, thanks, the ones I am after are items (3) (4) and (5).
