Home > General Chat > Trigger wheel for pick up from cranck
RED850
Member #: 89
Sydney Australia
does any one know who makes one for a mini, i am looking at doing an injection system with my turbo beast and i will do ignition too and i am just looking at trigger wheel set ups.
if any one can help that would be tops
thanks
Grant
179hp on 12psi 1293cc of pure A series
14.0et @101 mph
what ecu are you planning to use? I assume this is going to be fuel injecteced and turbod. Are you still using a 5 port head?
I can supply a computer file that will allow you to get a trigger wheel laser cut from 10mm thick steel. You can then get this in a lathe, and machine it so it drops behind the front pulley.
Let me know if you want a copy.
If you are tempted to do an injection system, speak to Jim or myself first... The A-Series is a nightmare to inject, despite what minispeed will have you believe...
http://www.planet.eon.net/~chichm/efi/efi.htm
and
http://www.planet.eon.net/%7Echichm/efi/siamese.htm
are the best resources for information on this subject, written by a proffesionally qualified engineer who has spent many hours researching the subject and physically trying to make it work properly... The only system 'out there' at the moment that seems to work properly is the unit from MBE- which is very expensive *frown*
Edited by turbodave16v on 25th Feb, 2004.
Dave, please can you email me that DXF.
f**k you.
ok then...
cheers
Doodmeister
Member #: 149
Alberta, Canada
Hi.
Is it a 36-1 tooth pattern ?? if it is can i get a copy of the file please as i also looking into doing a EFI system for the 5 port head.
So Jim and Dave you've both got A-Series Engines running on EFI then ?? what systems are you using and is it a 4 Injector setup or just the 2.
I've seen local to me a Green mini turbo thats running the Emerald ECU and it runs great on the track at Curborough so he must be doing somthing right although i think it's still running a little lean at the high RPM due the fuel robbing effects of the 5 port head.
I'm told Weber is the best setup for the 5 Port head on the mini.
Thanks
Karl.
I've got the Emelard ECU, and dave uses DTA, none of us are currently running injection, but dave has in the past, and I plan to give it a god in the future
RED850
Member #: 89
Sydney Australia
Jim and Dave,
i have read many threads here and on MM about your cars and im sure you have seen my name too.
i will be fitting a alloy cross flow 8 port (ken Elder OZ) and then fitting twin Injection perfection throttle bodies (see link) from there i may change my turbo from the T28 to somthing else but not an issue right now.
I want to run cranck fire ignition and fuel through a microtech (OZ see link).
I know the 5 port is just cr*p for injection so i am not going to even bother with it.
I am coming to the UK in July and August this year as one of my mates from OZ is pinching one of you ladies so i am going for the wedding so while I am there i want to buy many things that you just cant get here in OZ.
let me know your thoughts.
http://www.injectionperfection.com.au/
http://www.rigoliracing.com.au/microtech.htm
14.0et @101 mph
should be pretty striaght forward with an 8 port head (I mean, even I could work it out) Wish I had the money for one.
8 port head is an absolute doddle to inject!!!!
I'd be using a 'plenum' with a single throttle bodt rather than one butterfly per inlet tract mind - this will also allow it to stay in a roundnose with no external mods...
200+++ hp would be reasonably easy to get with a decent injection system, 8 port head and decent turbo....
Keep us upto date on your progress mate, I will be very interested to hear how you get on.
RED850
Member #: 89
Sydney Australia
Dave,
yeah i have thought of that too and it might be easier aswell, ands yes it is a must to keep it all under the stc round nose bonnet, well it is still a bit of yet but i will keep you all posted *happy*
14.0et @101 mph
RED850
Member #: 89
Sydney Australia
well i have got a secong complete A series engine to play with now so i will start to strip it and work from here.
here is a pic of a guys i know with an injected 8 port but no turbo
Edited by RED850 on 8th Jul, 2005.
14.0et @101 mph
im nursing a semi
lol @ wolfie, very sexy! and in a pickup
Doodmeister, they guy you are on about is Graham Harvey. He is a member of this forum and has written a bit about is car here:
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=4952
Red850, if you're flush with money you can buy one like this from minispeed
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=4792
I think KAD also make a wheel and pickup kit
Wil
Edited by wil_h on 8th Jul, 2005.
RED850
Member #: 89
Sydney Australia
yeah i read both of those posts and have enquired about the KAd one, Minispeed seem to be a bit funny to deal with, and we all know the quality of work that comes out of KAD.
14.0et @101 mph
get it direct from kad
that 8 port is beautiful
Red850, how are you getting along with this??
Do you have any contact numbers for Ken Elder?
turbo hogster
Member #: 178
stowmaket suffolk
when you are over here buy as much as you can and ditch the shreadies in the bin lol.
new kecks will be cheaper to buy in oz than mini bits.
but looks a awsome prodject.
keep up the good work
Mike
Member #: 107
Sunny Sussex
y get the KAD kit, comes with a bracket to hold a cossie crank sensor but a simple mod will allow you to fit an Ford EDIS sensor.
I'm really behind with the project at the mo, must get my ass in gear.
