Home > Help Needed / General Tech Chat > 1293 turbo or 1380 turbo
jimmy
Member #: 829
essex
i`m building a turbo engine and the pistons for 1293 are the same money as the 1380 turbo what one do you think ?
Edited by AlexB on 5th Mar, 2006.
1293 Turbo mini
Dangerous
Member #: 417
A 1380 can't be rebored (well it can but the pistons are rare)
Dangerous is right!
having said that my next motor is going to be a 1380 + an 84mm stroked crank
back for back the bigger cc will always make the most power!
given the same amount of boost but..... there are slight pitfalls nothing to worry about untill you want the...
"Ultimate Turbocharged A series Engine".
my moneys on the 1380*wink*
Nick
Member #: 154
Midlands
i'm the same as ben, i'd planned for my next motor to be a 1430. dunno why but i just fancy having a bash now that JE have bought out some forged 18cc jobbies...
Skinns46
Member #: 165
Cambridge
I'd go 1380. Benross and bud why don't you go the whole hog and go 1460. You can get a nice 86mm forged crank...only trouble is i think there about a grand. :s
http://photobucket.com/albums/y139/Skinns46/
hippyinamini
Member #: 520
nr hull
im running a 1380 with a t3 at the moment and loving it, but i just modded what i already had so it was the easy route for me. the biggest problem was getting the CR down. even with 11cc pistons and a head modded by benross ive still only managed about 8.5 - 1
although ive seen some rather swanky 18cc forged pistons from avonbar which are on the wish list for next year.
steve.
doh! why did i start messing with it!
jimmy
Member #: 829
essex
hippyinamini was they the pistons from avonbar at about £250.
1293 Turbo mini
Dangerous
Member #: 417
J.E. make 18cc 1380 pistons,or you could use low hieght(1430/1460) pistons as they stop approx 4mm down the bore on tdc.
But don't mention squish
jimmy
Member #: 829
essex
what`s the money on them £400 the abouts
1293 Turbo mini
Dangerous
Member #: 417
omega are about 250
hippyinamini
Member #: 520
nr hull
no more like £400 ish im afraid! acralite? i think their called, forged either 14 or 18cc
last time i checked anyway!
people seem to be doing well with this sort of CR tho, T3tones RR results on the other pages speak volumes. and my engine is very similar but not yet been near the rollers in its current spec.
1380, 11cc cast omega pistons, a stg 3 head modded by benross, kent 266 cam, megajolt ignition, plus all the s/c stuff undernieth.
just on the look out for a nice intercooler and some 1.3:1 roller rockers. to finish the job.
steve.
edit:
lol beat me to it
Edited by hippyinamini on 5th Mar, 2006.
bri the 18cc je pistons are they made for turbo application???
Nick
Member #: 154
Midlands
yeah they're available from morspeed last time i checked, same price as the accralite ones i believe.
AV-R Technologies
Member #: 345
Guildford Surrey
The £250 omegas will be cast not forged. JE's are £402 plus vat. Our Accralite our £353 plus vat. Just to give you a bit of info there. I've had a good look at both and there isn't much difference between the 2 on the face of it. The difference comes in the heat treament! OH and the price. *wink*
http://www.avonbar.com
avonbar, acralite would be my 1st choice
but its the pin height to to get a stroked crank in there
like mentioned above
AV-R Technologies
Member #: 345
Guildford Surrey
Benross there being made as we speak!!! Forged of course. Only with 6 or 11cc bowl i think. There is just no demand to get them with a bigger dish. Will let u know when we get them.
Avonbar....
Now, let me understand something here.
You say there is no demand- despite the (now) realisation of the 1380 turbo engine poitential, without the apparant drawbacks stated (and believed) for soooooo many years?
And JE is the only current supplier of such pistons?
ah,hum. I'm not understanding.
is it true that JE pistons use a smaller gudgeon pin?
Do Acceralite pistons used the same size pin as omegas?
thanks avonbar
the point been to make a Killer motor you need all the cc you can get.
especially with a stroked crank of 84 0r better 86mm
the piston ccs in the tops need to be increased,conciderd
18 / 22+cc
i honestley believe that there is a demand & a bigger one in the near future for these pistons*wink*
as shortley the fastest times with an A series motor will be made using a stroked cranked turbo motor.
its the way forward.
thanks pete
i do agree with you but we are stuck with a slight problem with the A series.
we cant go over board any more with bigger bores*frown*
the only way is to stroke it*wink*
a well stroked A series will still hang together at strokes up to 86mm with a turbo blowing at it on 20+ psi of boost
turbo engines, in essence is a torque mulitplier, nothing more.
turbo engines respond well with massive amounts of torque in stroked engines.
this is the only option we have in getting bigger ccs in the
A series
pete*wink*
I'll agree with the low speed torque, my approach would be to use taller gearing, with high compression as you can make more use of the low down torque to hurl the car out of the bends. It'll seem slower 'cause your not screaming the nuts off it but I reacon you'll get the same result!
Leonard
Member #: 806
Cirencester, Gloucestershire
the je pistons use a smaller gudgeon pin than standard (the +020" 18cc ones i have do) so this is extra cost for the rods to be bushed
thanks leonard
any one know about the short pin height ones
in 73.5mm ?
AV-R Technologies
Member #: 345
Guildford Surrey
Our forged pistons use the standard gugeon pin size. No rod mods. TurboDave i'm not clear what your saying???? We do forged piston at 73.5mm with 18cc and 14cc dish. What we can't get done is the pistons ben wants. Big dish for a long stroke engine. Simply because we have to get a batch done and we would never sell them,lol.
It will be interesting to see how your engine will perform Ben. Keep us posted.
Edited by AV-R Technologies on 8th Mar, 2006.
