Home > Help Needed / General Tech Chat > crankshaft end float
nogin
Member #: 487
westbury, wiltshire
bit confused as to what thrust washer i need, i have 0.30 of movement at the mo and need to get it to 0.006, what thrust washer do i need or do i need to measure the one i have on there at the moment as well
cheers
"Can I legally marry people now that I am ordained in the Church of the SubGenius?" aka i know jack sh"t
i also make things
i love coming home to chrome
0.30 is 300 thou or 1/3" which can't be right.
I assume that the 0.30 is in mm, so the float you have in thou is around 12 thou (0.012").
Now, this would have been easy to fix when minispares sold +3 thou thrusts, sadly they don't anymore.
Are you measureing the float with new thrusts, or using old ones?
A new set of standards might help, I somehow had a set of +10s in my old engine, not sure where they came from though.
Wil
nogin
Member #: 487
westbury, wiltshire
i am measuring the endfloat with the old one in and yes just looked at feeler guage and it is 0.012 thou, doh, so if i got +6 this would bring the endfloat to 0.006 thou or am i getting it wrong
i also make things
You could either get of plus +6s of +3s for both sides.
However, I found that my old thrusts were 89 thou thick and new ones were 93 thou thick.
So if your thrusts were as worn as mine a pack of 4 standard thrusts could get the float right.
Wil
nogin
Member #: 487
westbury, wiltshire
self designated dumbass here i am meant to be talking about the
PRIMARY GEAR THRUST WASHER
so what would be the deal with this then as on minispares they give other thrust washers as 0.112-0.114 so what one would i need do you think this is why i am so confused i cant even think straight at the mo
i also make things
Dangerous
Member #: 417
Try a thinner gasket
Nick
Member #: 154
Midlands
if you've got 12 thou endfloat at the minute then take out the washer, measure it and buy a washer from minispares that is 6-8 thou thicker than the one you have in now.
Ouch those thrust washers are expensive! Hope I don't have to buy one *surprised*
Edited by Bat on 9th Mar, 2006.
Nick
Member #: 154
Midlands
minits do em for a tenner dude....much cheaper *wink*
Have you tried using other retainers?
I've found in the past that these vary in thickness and can reduce the float enough.
Wil
Edited by wil_h on 10th Mar, 2006.
This won't help with the primary gear, only the idler.
Nick
Member #: 154
Midlands
Wil
yeah did that one mine last time, turned the C washer round and it took up the excess float luckily :)
Yep, always worth trying a brand new retainer/c clip before splashing out on diff sized thrust washers, as they are £24/ea. (well, were when I bought my last one)
I've got loads of retainers and C-clips available, and normally get the endfloat right with a lot of messing about with these...
andeh
Member #: 97
Near Daventry, midlands
dont get new c-clip, just the retainer as the last one i got from minispares was next to useless.
