Home > Help Needed / General Tech Chat > verto to pre verto
TURBO ME
Member #: 772
new york
have a 998 with a pre verto clutch
what do i need from this set up to convert my 1275 verto turbo to a pre verto clutch system?
flywheel
flywheel bolt
tab washer
clutch backplate
drive straps/bolts
wok c/w release arm/plunger
clutch slave cyl
think that is all?
anyone else care to add anything?
jimmy
Member #: 829
essex
clutch slave cyl pipe
1293 Turbo mini
Spring for slave cylinder return if you want to go into the smallest of details.
Oh, and a good clutch for the turbo! *wink*
Edited by Bat on 9th Mar, 2006.
clutch release bearing, key'd washer (is that what you call the tab washer or do you mean the locktab?)
think thatd do it.
TURBO ME
Member #: 772
new york
great thanks everyone will get to it tomorrow then
