| Home > Help Needed / General Tech Chat > bi-metallic jet holder rivets | |||||||
10th Mar, 2006 at 07:52:21pm
hello all
10th Mar, 2006 at 08:22:03pm
Hi Nic,
Forum Mod 1140 Posts Member #: 93 Post Whore Near Lincoln |
11th Mar, 2006 at 09:57:45am
i tapped the one i did nic, and then fitted some screws (2BA) i think |
11th Mar, 2006 at 10:24:45am
ok then, im feeling a little slow when it comes to this, so:
Edited by Nic on 11th Mar, 2006. |
11th Mar, 2006 at 10:38:52am
Ive put the middle piece on the hob before and that is bi-metallic too, i cut/filed one out of stainless to the same shape.
Edited by T3Tone on 11th Mar, 2006. -MINI CLUBMAN 1380 TURBO- |
11th Mar, 2006 at 01:13:02pm
11th Mar, 2006 at 03:41:37pm
indeed, i will be taking step by step pics and hosting and posting them on this site |
11th Mar, 2006 at 06:25:46pm
next question:
11th Mar, 2006 at 06:49:12pm
I thought the idea of using 2 packing washers was so you could use Dan's cut plate between them, and do without the two either side of it, as shown in Nic's picture above?
11th Mar, 2006 at 07:21:46pm
i agree with you there tom, thats what i was originally thinking |
11th Mar, 2006 at 08:21:11pm
15th Apr, 2006 at 08:30:49am
One thing I don't get is:
15th Apr, 2006 at 08:53:59am
this is what i ended up coming up with:
16th Apr, 2006 at 05:15:04pm
I've now fitted the new steel strip directly to the 90 degree bit with no spacer in between. I cannot see that this does any harm if you compensate by adjusting the mixture a bit richer.
17th Apr, 2006 at 02:23:26pm
Looks fine Nic.
19th Apr, 2006 at 09:05:57pm
I ended up with this:
25th Apr, 2006 at 01:41:53pm
Another, possibly better picture of mine:
31st Dec, 2008 at 08:35:40pm
are these still available? I'm getting all sorts of strange running probelms esp when its cold. I was thinking this may be the problem changing my mixture in the cold? is the new strip made out of stainless? I run a supercharger and I don't care the TB is on the wrong side.
1st Jan, 2009 at 10:14:45am
1st Jan, 2009 at 10:48:24am
Not really hot restarts, these are to stop the carb leaning mixture off if fuel temp gets hot.
1st Jan, 2009 at 11:28:30am
does the replacement strip have to be petrol resistant? what material do you use or do you coat it before use? I run a supercharger and I don't care the TB is on the wrong side.
1st Jan, 2009 at 11:41:31am
leave uncoated On 19th Jan, 2010 wil_h said:
