Home > General Chat > flywheel removal
martpaul
Member #: 668
newton aycliffe (near durham)
HEy all,
i was just wondering where is the best place to buy the flywheel removal tool?
Oh and ive just found out i already have the non-verto setup! git i bought a flywheel a while back to fit!!!!! :(
martin
ben doodar
Member #: 595
stoke on trent
we sell one at halfords which is £15
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
having two non vertos is a good think *happy*
Alex
AlexF
martpaul
Member #: 668
oh ok!
I guess ill can keep it to try n make my stock look big!
When i removed the flywheel cover there was all this brown dust around the center of the case!
is this fram the clutch?
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
yup
don't break it in!
Its probably not abestos... but its nasty stuff!
Alex
AlexF
martpaul
Member #: 668
I use to crush flu lighting tubes for my uncle in the summers! ( he loved me that much)
so this is nothing! (only joking)
What should i use to clean it?
giallofly
Member #: 164
The Stig..
Newport Pagnell
The tools normally come with 2 sets of bolts, if you have a non verto clutch set up you will need to use the bolts ith the finer thread.
You may as well buy a can of brake and clutch cleaning spray or just a rag and thinnners does the job.
If the flywhell has'nt come off in a while it my me a twat to get off, i find removing the starter motor and giving a "firm twat" with a lump hammer helps when you have tightened that puller all you dare.
JF.
martpaul
Member #: 668
cool thanks,
im stripping the block so it can go off to morspeed to be cleaned and stuff!
While i weld the car!
i keep forgeting to take pics but if i do ill post them on here!
thanks martin
Yes, a firm twat from a BFH often helps matters.
To be honest in my younger days autograss racing minis, I did not have a flywheel puller, so used to rely on a hammer and twatting alone to remove flywheels......... it can be done by you have to be careful not to smash the transfer gear casing in the process.
Brocky
Member #: 224
Katy TEXAS
A big hammer is one of my favorite tools..If in doult give it a clought!!
I used to have a scaf bar with gaffa tape on the end and stick it in the started aperture with the other end on an axal stand. Then enter stage right the sledge hammer. The trick is to turn the flywheel 90 degrees before each wack !! also put an old sofa cushion on the floor next the flwheel.*happy*
