Home > Help Needed / General Tech Chat > Is a T2 turbo oil feed the same as a T3?
jamesfawcett
Member #: 218
Bingley, West Yorkshire
Justh ave to check because ive just been talking to Mirage, the braided oil feed hose that we all use for our T3 turbos, will the same one work for a T2 turbo?
One word answer:
NO.
Dangerous
Member #: 417
differant thread
jamesfawcett
Member #: 218
whoops, cant i just use the nut that screws into the T2 but still use the braided hose ive bought of another member for a T3?
Is the hole a different size?
Dangerous
Member #: 417
If you got screw on banjo ends you could change the complete end I suppose
^^ that's what I did.
See this thread on the subject
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=8057
whats the end of your pipe like?
you could get a different fitting that will fit the t2, but screw into the pipe/banjo
benjamin
Member #: 621
nsw austalia
well i used a t3 oil feed of ebay uk and made an adapter on a lathe
heres some pics *smiley* 7/16'' 24tpi is a UNS thread if you want to buy a button die
1152cc turboed mini clubman, most powerful 1.1L a-series?
http://boostmini.justboard.net/
SumpNut
Member #: 28
Avonbar were able to supply me with a pre made hose for a T25 at 7/16th 24tpi
jamesfawcett
Member #: 218
cool! made one up today out of old unions and banjos and things in a box, thanks for the photos benjamin helped alot!!
