Home > Help Needed / General Tech Chat > cam timing
nogin
Member #: 487
westbury, wiltshire
right had a look on the how to and in vizards book, i know how to find full lift, but i cant get my head round how to get the two dots to line up when at full lift, basically i dont understand the lining up bit of the dots as no one says how to do this only finding full lift on the cam, which i know is 108 deg as it is an avonbar phs 2 cam, can any one explain cheers
"Can I legally marry people now that I am ordained in the Church of the SubGenius?" aka i know jack sh"t
i also make things
i love coming home to chrome
Carl
Member #: 95
liverpool-on-sea
mr haynes will tell you how to line the dots up. basically with crank at TDC the dot on the crankshaft gear will be at about 2 oclock and the dot on the camshaft gear will be at about 8 oclock, so they point at each other if you get the idea.
this will give you rough cam timing but isnt accurate, have you got adjustable timing chain gears if so do the above then follow toms guide in the how to section to adjust it accuatly.
thats what i did anyway.
p.s if you havent got adjustable timing chain gears you can get off set woodruff keys
Edited by Carl on 20th May, 2006.
Forget the dots! Line them up when you fit the gears / chain so you know your roughly in with a chance. Then use the Vizard method to find your full lift timing figure.
If it's not 108 degrees then use an offset cam woodruf key to get it correct. Otherwise, buy adjustable cam gear and adjust *wink*
Either way gets the same result! HTH
Edited by Bat on 23rd May, 2006.
minit3
Member #: 602
what happens if you have a phase 2 cam and just line the dots up *indifferent*
It will work, just maybe not as well as it could. The trouble is that unless you measure it, you don't know whether it is spot on or miles out.
My last phase2 cam line up perfectly without any offset woodruffs. First one needed a 6-degree I recall !!!
I'm having a bit of a problem with my cam timing. I've honed all the follower holes, but number two is sticking slightly. Maybe I've used too much cam lubes as well. There should be no reason for me not to use #4 inlet for timing should it? I've never had to before, although I do see that this would be a nice way to check the cam's accuracy as well. Any thoughts?
