Home > Technical Chat > Pre 1985 differences
Brocky
Member #: 224
Katy TEXAS
I have recently come across a Pre 1985 turbo engine, and have notice a few differences:
Carb plate is a 2 piece
Plenum is black not grey
Dizzy has clip on cap and seperate amp. (Apparently has better advance curve than post 85 )
Fuel regulator looks different
Speedo has electronic boost gauge on rev counter.
Are there any other differences that are worth noting ?
I did a search and didn't find any topics
Cheers Brocky
<Moved to Tech Chat TF>
I am also breaking a turbo engine at the moment which is complete apart from the crank which went in a race engine. Will have to get it on the for sale
Edited by Tom Fenton on 23rd May, 2006.
The Mk1 dizzys are different yes, and allow the use of a side-entry dizzy cap.
However the "different advance curve" bit is a long running myth, and is not true.
Brocky
Member #: 224
Katy TEXAS
Opps just noticed I started this in the shows your bit doh!
Anyway thanks Tom *happy* I won't bother changing mine over to the early one then just wait till I get a mega jolt set up.
Cheers brocky
Dangerous
Member #: 417
I should think the square drive on the gearbox for the speedo cable is the same as a mini on early ones,as later metros have valeo instruments which use a smaller square drive cable.
