| Home > Help Needed / General Tech Chat > super budget gearbox rebuild! | |||||||
125 Posts Member #: 751 Advanced Member Aberdeen |
29th May, 2006 at 11:30:37am
as life would have it, finished my exams a week ago, got the summer off uni to get stuck in and finish my rebuild then i go and break my ankle!!!
29th May, 2006 at 11:46:01am
10psi on helical drops? I'd give them a couple of months at best.
29th May, 2006 at 12:48:00pm
If you got hold of some boxes, there is no need to change more than the bearings Tom describes. I mean, you don't need new baulk rings if the ones you've got are OK. No new shafts shold be needed either. I don't see a problem running an uprated single diffpin either, but be prepared to rebuild next summer. Also, the planet gears will need replacing if the pin is worn.
982 Posts Member #: 97 Post Whore Near Daventry, midlands |
29th May, 2006 at 01:19:22pm
Depends on your hoard and inclination, if u have several 998 low mileage boxes, and do what vegard suggests you could do it on the cheap. However, its difficult not to change the bearings as they are nearly always nakered.
29th May, 2006 at 03:06:24pm
If you use the torrington idler bearings - that's your best chance of success with the helical idlers. On 17th Nov, 2014 Tom Fenton said:
29th May, 2006 at 03:14:22pm
how do you know if baulk rings are in good condition?
29th May, 2006 at 03:21:20pm
You should be looking at a 1mm gap between the back of the ring and the front of the clutching teeth. Make sure you don't mix-and-match the rings either; keep them on their appropriate gears.
29th May, 2006 at 10:50:14pm
29th May, 2006 at 10:58:17pm
my turbo verto lasted about 1000 miles at 10psi, which was around 120lb/ft, plus however many miles it did in the metro...
29th May, 2006 at 11:26:20pm
I'm thinking of Turbo verto cover, with AP race/ rally plate......
30th May, 2006 at 12:55:42am
Jukka runs helical drops on his 1380cc turbo - and has done for MANY years... On 17th Nov, 2014 Tom Fenton said:
2nd Jun, 2006 at 09:53:10am
Yep, roughly 50000 kms. And they were s/h when I fitted them. I did replace the primary gear on the crank tail due to bush wear but since that was s/h too cannot really say how much was caused by turbo use. Mine are pre A+ variety like the gearbox, with smaller diamter idle gear. I would not worry about them at 10 psi as long as you shim the end floats to the factory spec.
2nd Jun, 2006 at 11:06:20am
such hardship Jukka!!
AlexF |
