Home > General Chat > Its that time again, burlen orders please :-)
ordering from burlen
full turbo carb rebuild kits £46 posted
all other bits list and i'll order *smiley*
Ben H
Member #: 184
Melton Mowbray, Pie Country
What do I need to convert a NA carb to a turbo carb? Just the rebuild kit and the instruction on how to do it or are there other bits?
http://www.twin-turbo.co.uk
think thats it ben.
I need a BDD needle. Is it worth you adding that to your order ? or shall i just order it myself from Burlen ?
Phil. *smiley*
Iain,
I need the following for HIF setups:
2 off the little springs that sit atop the needles.
2 off the 'ferules' that secure the 'inner' cable on the choke spindle.
Can you get them before Avon - and I'll pay you then?
i can order both for you phil/dave
avon paying is no problem for bits as well.
the ferrules, do you mean the piece that attaches the cable to the choke arm? those annoying little bits that are easy to loose as they fall out as soon as you take the cable out?
aye, the bit that is a 'female' part that the cable goes thru, and then the tiny scrfew that screws into the female part and clamps the cable...
And I've lost several, hence needing some!
Correct term is solderless nipple.....
Can I have a couple of the clips that secure the choke cable outer to the bracket?
And can they supply the clip that secures the throttle cable end to the pedal??
I believe that's a Rover part Tom....
I think these are called solderless nipples?*laughing*
Nick
Member #: 154
Midlands
if you can get em iain i'll have some little bits for spares.
2 of the things that hold the choke cable to the arm.
2 of the choke outer cable clamps on the carb spacer
alright to sort em out at avon?
i'm not sure burlen do the bits that secure the outer cable to the bracket but i'll ask. if not minispares do them for 30p each *smiley*
either i can get a boat load or someone else can to hand out at avon to save on postage *smiley*
bud no issues with sorting out at avon.
Brocky
Member #: 224
Katy TEXAS
Iain,
I need the red flet washer that goes under the black dashpot cap and the c-clip that holds the piston in the pot.
I also need the the big dash pot o-ring
Brocky
brocky - The dashpot o-ring is the same as the float bowl one. For the money - I'd get a few; Always handy to have some on standby.
Brocky
Member #: 224
Katy TEXAS
Good point DC.
Iain, can you times that lot by 3 please,
Brocky
all those bits are on the way. couldnt get any solderless nipples though but got 3 of these. i wanted one urgently so had no choice but if you want a couple they're yours.
Sorry tom the choke clip appears to be a rover part
Couldnt get the washers that go under the black cap either but i think i have some spare as i have a "broken" kit anyway.
http://www.burlen.co.uk/partDetail.aspx?partID=44452
most bits were in the pint or two price range for the lot *wink*
CLEG1300TURBO
Member #: 1013
OXFORD
do this 'burlen' place sell uprated carb needles?
they sell any needle you like. they own the SU company *smiley* and manufacture all the parts.
although the order is in now
right, all the bits are here but they forgot your needle phil *frown* i'll get them to send it direct to you.
all other bits send me a pm with where they're going (think most are avon) and we'll go from there.
i have rebuild kits, one is ben's the other one is for? anyway its spare *smiley*
martpaul
Member #: 668
newton aycliffe (near durham)
its for me! :) and a T2 rebuld kit!can I get them at avon? thanks martin
yep, no worries. i'll try with the t2 rebuild kit. what model? or what was it off?
martpaul
Member #: 668
me thinks a r5 but ill double check!
