| Home > Help Needed / General Tech Chat > Intercooler Size | |||||||
207 Posts Member #: 193 Senior Member Aylesbury |
20th Jun, 2006 at 10:03:59pm
Can you go too big on the size of the intercooler. I have one from a subaru WRC that i am thinking of using. What are the advantages and disadvantages. Is lag the only downside to oversizing the intercooler. (Maybe Antilag could help cure this).
20th Jun, 2006 at 10:05:03pm
Your main restriction is what will physically fit.
20th Jun, 2006 at 11:15:27pm
for get the antilag for the road
21st Jun, 2006 at 06:31:37pm
i dont think you need to fit the biggest intercooler you can get. lots of people on here have smller ones fitted in a good place and have top notch results.
21st Jun, 2006 at 07:26:27pm
john flan seen a
809 Posts Member #: 224 Post Whore Katy TEXAS |
21st Jun, 2006 at 08:12:46pm
On 21/06/2006 19:26:27 benross said:
john flan seen a "whole 30HP increase" ....just ... by swapping from a 2WD cossie Intercooler & shoehorning a 4WD one in mind you johns motor was approaching the 200+ mark if you can get the scoobi one in with out too much bother, i would go for that! carl is right, to a point. with a larger cooler the turbo would take a moment longer to spool up thats the down side. its a compromise you need maybe???
Does the 4x4 cooler use 60mm dia ports ? Also do you have to change you set up in terms of timing and mixture when you fit a cooler, only asking as I'm about to fit one ? BTW - I took my buddy VTEC Pete out for a spin this weekend, and even though I am running her in, he gave it a name, the "Brocket"...cause I'm a brocket maaannn, nah nah nah nah nah nah nah nah nah nah nah....
21st Jun, 2006 at 08:32:17pm
21st Jun, 2006 at 09:04:11pm
It was a Series 1RS turbo cooler for a 4x4 sapphire item.
21st Jun, 2006 at 09:29:37pm
Thanks guys,
21st Jun, 2006 at 10:21:24pm
ive got a cozzy 2wd cooler in me clubby its a perfect fit! no longer a series, but still 1.3 turbo.
22nd Jun, 2006 at 10:54:29pm
Cool BTW - I took my buddy VTEC Pete out for a spin this weekend, and even though I am running her in, he gave it a name, the "Brocket"...cause I'm a brocket maaannn, nah nah nah nah nah nah nah nah nah nah nah....
![]() 508 Posts Member #: 487 Post Whore westbury, wiltshire |
22nd Jun, 2006 at 11:20:06pm
you mean a peltier cooler element like from those small fridges "Can I legally marry people now that I am ordained in the Church of the SubGenius?" aka i know jack sh"t
22nd Jun, 2006 at 11:40:44pm
Did you know if you reverse the polarity you can use a temp gradient across a unit to produce current all be it slightly less effieciently?
Edited by Brocky on 23rd Jun, 2006. BTW - I took my buddy VTEC Pete out for a spin this weekend, and even though I am running her in, he gave it a name, the "Brocket"...cause I'm a brocket maaannn, nah nah nah nah nah nah nah nah nah nah nah....
23rd Jun, 2006 at 12:08:37am
would a r5 gt turbo intercooler be any good for a mini?
My build thread..
23rd Jun, 2006 at 12:15:16am
Would be a good choice if you can get it in a good air flow also you can get an all alloy item for higher boost applications or alternatively strap the standard item to stop the end caps blowing off !!! BTW - I took my buddy VTEC Pete out for a spin this weekend, and even though I am running her in, he gave it a name, the "Brocket"...cause I'm a brocket maaannn, nah nah nah nah nah nah nah nah nah nah nah....
23rd Jun, 2006 at 02:38:41am
I would say you can go to big. As if your not careful if you have a cooler day, you might find you keep freezing up your carb and the car keep cutting out, just some thing to think about.
23rd Jun, 2006 at 10:12:36am
which cooler are you running mat ?
23rd Jun, 2006 at 11:10:25am
It's not any type mate it one i had made up to fit the space i had. Best 1/4 mile 13.2 seconds @116 mph
23rd Jun, 2006 at 11:24:43am
I have had a look at the potenitial of using Peltier elements for cooling intake air.
23rd Jun, 2006 at 11:43:53am
yep there's no way a peltier will cool the inlet charge to any degree,
23rd Jun, 2006 at 11:54:21am
And thats got to come off the crank.
Edited by Paul S on 23rd Jun, 2006. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
23rd Jun, 2006 at 01:28:09pm
Fair enough just thought you could use them to cool the intercooler down before the start of a hill climb or sprint while you are waiting to start. Like the oposite of a tyre warmer before a race.
23rd Jun, 2006 at 02:05:08pm
You could make a generator out of it, but not enough to lose you battery or make much difference at the crank by lowering the load on the alternator. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
