Home > General Chat > Mini runs :D
jamesfawcett
Member #: 218
Bingley, West Yorkshire
At last!!! the mini runs, absolutely perfect. And... thank god no oil leaks!!
Just done the 4th oil change on it and this time put in some nice expensive 10/40 to make double sure there is no metal in there.
Im really happy with how nice it drives and runs. Not reved it high yet though so not sure how it will run on boost, first im just going to go over everything and check everythings ok.
Fitting bonnets is a pain in the arse to get them perfect!
Im using the TT map from the FAQ section. Does anyone know what the spec was when it used that? do you know how much boost they were running? will i be ok, until tune up, to use the TT map with just 7psi or should i alter the values a little?
SurfToLiveLiveToSurf
Member #: 748
Cirencester, Gloucestershire
well done man, good news theres no leaks, nothing worse after a rebuild. hope it runs ok on boost, let us know how it goes!
1310 - Supercharged 16v Twin Cam - 190BHP - SC Built.
1293 - Turbo 16v Twin Cam - Build Commenced
excellent feebs
a big slog over for now!
TT map has maximum advance of 26 deg, so should be ok running 7psi, we ran around 18psi.
jamesfawcett
Member #: 218
thanks *happy**happy*
I am really confused about air fuel. In my other cars ive always put this digital guage in, i have it on the setting that always shows a number. The number is always arround 14.7. it goes up to 20+ when decelerating in gear overrun.
Im going to set the mixture so that its at about roughtly 14.7 for idle.
What i dont understand is the other setting, it also has a Air fuel reading, and its a number then some decimals, its sometimes arround 1.50 or something. Is this the voltage? Also it has a light which turns from green to orange to red for how rich its running.
Is it just two readings for the same thing?
AllanMcD
Member #: 414
Dalbeattie Scotland
What was wrong when it only ran for a few seconds?
http://www.rabdunn.co.uk/
jamesfawcett
Member #: 218
Haha did you not see the photos??
It fell inside the engine!
Carl
Member #: 95
liverpool-on-sea
feebs i think he means what was the outcome of this http://www.turbominis.co.uk/forums/index.php?p=vt&tid=9825
great news there.
jamesfawcett
Member #: 218
Oh sorry i forgot about that post!!
Well i took the carb off and took it all apart and everything was fine, and as new, no gunk or anything. Put the carb back on, and did daves T piece trick (after checking everything in his guide like renewing the balance pipe etc) and it started fine!
Carb rebuild will be on the list for after avonpark :) Planning on driving it to lake district this weekend though if i can get it tuned and MOT'd in time
AllanMcD
Member #: 414
Dalbeattie Scotland
You plonker I knew about the dizy drive.
Thanks for the update and keep the 17mm spaners*wink* out of your engine.
Allan
jamesfawcett
Member #: 218
hahaha! *wink*
