Home > Show Us Yours! > Rolling Road results!
Well, Where do I start?
Droving to Colchester to see uncle ray and all seemed in order.
Got to the mini roundabout just before the industrial estate, change down a gear and the clutch pedal goes soft. I struggled to get in into gear, just about goes in and just make it to T&M.
It seems that something in the clutch has collapsed, allowing the arm to throw so far out that the piston in the slave popped out, pissing all of the fluid onto the floor.
Great.
Luckily I opted for the recovery service as part of my insurance package, so I gave them a call and the nice lady at the other end of the phone said that a recovery lorry would be there within an hour.
So, in the meantime, we asked Ray if he could run my friends 1100cc clubby to pass the time and get some sort of result out of the day.
Just as he pulls it up to the rollers, the clubby starts to piss out water!! The pump was leaking.
Great
Recovery lorry turns up, loads up my car, but as we are just ready to pull away the NS right type decides to let all of it's air out.
Great
Come home to find my family in pieces because my Nan has passed away.
Great
All in all, one shitty day.
Sorry for the rant. Any ideas on the clutch? bearing?
Edited by theoneeyedlizard on 2nd Aug, 2008.
Jordan
Member #: 1392
Pointless Post Whore
Liverpool, North west
Sorry to hear about your dreadful day Gaz.
Had you set the over throw to the ref in haynes?
Edited by Jordan on 2nd Aug, 2008.
Haven't touched any of it as it was all set up already.
mate, thats harsh as fuck. good luck with the car and sorry to hear about your nan :(
El Potter
Member #: 2169
Malta (Ex. Scotland)
Really sorry to hear that mate.
All the best with car.
Warning:Stig in Training
Carl
Member #: 95
liverpool-on-sea
sorry to here about your shitty day and condolunces (sp?) about your nan.
urm not sure about your clutch but yo should be able to get the wok off without taking engine out.
is the pin still in?
El Potter
Member #: 2169
Yeah wok can off without removing the engine,but the bottom 2 bolts are really really difficult to get at cos of the subframe.Only way I managed it was by bending a 13mm spanner so the end was 90degrees to the shaft.
13mm? Do you mean 11mm.
I undo the engine mount on that side, undo the two steadys and jack the engine up, to get to those.
Right, the wok is off, the release bearing looks ok (to my untrained eyeballs).
Could it just need re-adjusting, or do you think that something has shat itself?
Hi Carl,
All the clevis pins are in place.
Ben.
Member #: 1064
Formally Whyte_ben
Horndean, Hampshire
Sorry to hear about your nan mate.
Good luck getting the clutch sorted.
Build Thread Click Here
Carl
Member #: 95
liverpool-on-sea
take the arm off the wok and check the ends not snapped or the bit where the ball off the arms sit isnt cracked/worn/broke.
Just spoke to Joe (mini13) and he suggested (as Carl did above) that the arm might be at fault.
And...
You are both correct.
Any one got a spare pre-verto arm?
Sorry to hear about your date, mate.
sorry to hear about your Nan,
now how old is the arm?.
Thanks guys.
Carl, I'm not sure how old the arm is.
how about showing us a macro close up of the break, so we can figure out why it broke,.
carl
Carl
Member #: 95
liverpool-on-sea
not really that old only as old as the engine gary so couple of years and couple of thosand miles, tops, and it was a new one, should be a receipt in the stuff i gave you mate
I thought that was the case, but apparently the new ones are made of cheese.
SORRY to hear that gary ...been there with MANY! berievments ....... *frown**frown**frown*
one step at a time buddy .. as i do.
yes the new ones are made of cheese.
seek a good genuine one.
i will be in contact with you thats for sure!!!!!!!!
damn not the greatest of days then
Give yourself some time, itll come round in the end
Sorry to hear of your loss :(
The arm looks very roughly machined, looks like could it have cracked across one of the grooves?
Jason G
Member #: 1459
En-suite user
Braintree, Essex
On 19th Jan, 2010 wil_h said:
It looks like the chinese have done aniother bad job of the heat treatment, [nothing new there] it is clearly hardened through ,making it brittle,
the origional rover BL ones would bend along the length of the ball end, but not snap.
carl
sorry to hear it mate. chin up though it looks like your working through it which is the best thing to do.
get a new genuine arm on it like the others have said and get it back on the rollers. hopefully that might put something good on the table for ya.
