| Home > Help Needed / General Tech Chat > Piston Rings 1275 Turbo Rebuild | |||||||
809 Posts Member #: 224 Post Whore Katy TEXAS |
4th Nov, 2012 at 04:05:38am
Alright Guys,
Edited by Brocky on 4th Nov, 2012. BTW - I took my buddy VTEC Pete out for a spin this weekend, and even though I am running her in, he gave it a name, the "Brocket"...cause I'm a brocket maaannn, nah nah nah nah nah nah nah nah nah nah nah....
4th Nov, 2012 at 05:32:44am
Hi they are NLA sorry to say, I would shell out and get +20 omega10CCS dish cast pistons and a rebore, job done buddy
4th Nov, 2012 at 05:50:18am
Hey Mr Ross (Steve),
4th Nov, 2012 at 09:51:57am
How worn are the bores? Take the block to a machine shop and get the measured. If they are tight enough, get it honed and use new rings. If they are worn, bang the old ones back in. As long as you don't damage them getting the pistons out and put them back in the same bore, they should be OK (maybe not as OK as before they came out, but should still seal). On 11th Feb, 2015 robert said:
4th Nov, 2012 at 10:43:02am
Is there any lip in the top of the bores? If there is you will probably want a rebore, if not you should get away with a hone. I ran 5 thou piston to bore clearance on my last motor and compression was perfect, with no oil comsumption, ring gaps were at the limit of reccomended tolerance though.
4th Nov, 2012 at 12:14:44pm
On 4th Nov, 2012 Brocky said:
Hey Mr Ross (Steve), Hows it going, that head is still going great guns btw Maybe you havn't had you coffee yet but I actually have 2 off, unused boxed sets of 1275 turbo piston rings, still in the paper pouches, possibly the last 2 from minispares. So are you saying don't put the old ones back in ? Maybe better if I give you a phone? Same number ? First thing I would do is take the rings out of the packest and check that they actually fit the pistons. There have been people who have bought 'turbo' rings from Minispares and they did not fit the turbo piston. Have a search
4th Nov, 2012 at 02:25:58pm
Now you have me thinking...
4th Nov, 2012 at 03:43:24pm
the oil ring is the problem. Apparently they are 'deeper' than the groove in the piston, therefore will not compress up enough to fit in the bore.
4th Nov, 2012 at 04:48:15pm
Understood will have a look at it
4th Nov, 2012 at 05:02:47pm
4th Nov, 2012 at 05:36:56pm
Not something I've heard of ?
4th Nov, 2012 at 06:17:40pm
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=355598
4th Nov, 2012 at 06:29:37pm
Perfect,
4th Nov, 2012 at 07:23:34pm
5th Nov, 2012 at 03:36:52pm
Ok Sprocket,
Edited by Brocky on 5th Nov, 2012. BTW - I took my buddy VTEC Pete out for a spin this weekend, and even though I am running her in, he gave it a name, the "Brocket"...cause I'm a brocket maaannn, nah nah nah nah nah nah nah nah nah nah nah....
5th Nov, 2012 at 09:59:48pm
On 4th Nov, 2012 minimole23 said:
Is there any lip in the top of the bores? If there is you will probably want a rebore, if not you should get away with a hone. I ran 5 thou piston to bore clearance on my last motor and compression was perfect, with no oil comsumption, ring gaps were at the limit of reccomended tolerance though. Hey Minimole, I just did the Haynes check using the piston 3/4 inch down the bore, it recommends that anymore than 10 thou should be rebored. There is a slight lip on the thrust side of the bore but I can only just get the 0.01mm (3.93Thou) feeler down the side of the piston, so sounds like slightly less piston to bore clearance than yours, but did you measure the clearance after you deglazed the bores for new rings ? Actually based on the recommended Skirt clearance - Top figures 0.1mm is below the top tolerance of 0.114
Cheers Brocky Edited by Brocky on 5th Nov, 2012. BTW - I took my buddy VTEC Pete out for a spin this weekend, and even though I am running her in, he gave it a name, the "Brocket"...cause I'm a brocket maaannn, nah nah nah nah nah nah nah nah nah nah nah....
5th Nov, 2012 at 10:16:28pm
That engines still under the bed as a spare. I'll stuff a feeler gauge down the side tomorrow and see what I can find.
5th Nov, 2012 at 10:39:12pm
Just spoke to total seal and as you say the ring gap issue goes away with thier no gap ring,
6th Nov, 2012 at 08:07:24am
Now then gents, i will throw a curve ball into the mix here,
6th Nov, 2012 at 03:47:24pm
Thanks Carl,
Edited by Brocky on 6th Nov, 2012. BTW - I took my buddy VTEC Pete out for a spin this weekend, and even though I am running her in, he gave it a name, the "Brocket"...cause I'm a brocket maaannn, nah nah nah nah nah nah nah nah nah nah nah....
6th Nov, 2012 at 04:12:25pm
I would fit the TS rings anyway, the old ones are probably 25+ years old and are bound to be worn. We successfully put 25psi+ through the van with them and it always ran very well. On 11th Feb, 2015 robert said:
6th Nov, 2012 at 04:15:15pm
Just did the ring gap, came in a 0.5mm on the top comp ring 3/4 inch down the bore, this is 0.2mm over the recommend end gap,
6th Nov, 2012 at 04:20:58pm
Surprised me how strong the original MT pistons actually are.
Edited by John on 6th Nov, 2012. If something is worth doing, it's worth doing half of. |
6th Nov, 2012 at 04:45:10pm
Pistons have cleaned up remarkably well,
6th Nov, 2012 at 05:50:40pm
What CC in the head do you have that has brought thr CR down below 8.2?
