| Home > General Chat > ot - Handling Question... | |||||||
2nd Nov, 2006 at 09:47:24pm
If you have a car that is on (say) factory tyres, and has a tendancy to understeer, will changing the tyres to a much softer, grippier compound give the exsct same handling characteristics, just with a higher cornering speed?
138 Posts Member #: 138 Advanced Member |
2nd Nov, 2006 at 10:05:44pm
All modern car out of factory is made to understeer... regardless what tyres you are using.
2nd Nov, 2006 at 10:15:11pm
Edited by Bat on 2nd Nov, 2006. VEMs Authorised Installer / Re-seller. K head kits now available!
223 Posts Member #: 598 Senior Member Gaol |
2nd Nov, 2006 at 10:40:51pm
have a play with the tire pressures before you go changing rubber, this can affect the way the car handles significantly, try a couple of pounds out of the front tires.
On 5th of Sep, 2006 at 05:47pm mini13 said:
I reckon if his brains were gunpowder he couldn't blow his own hat off... |
2nd Nov, 2006 at 11:48:26pm
it will be the same if you alter nothing other than the tyres, |
3rd Nov, 2006 at 12:52:49am
Vroom, bat, imp.
Forum Mod 1140 Posts Member #: 93 Post Whore Near Lincoln |
3rd Nov, 2006 at 06:39:13am
i would say that changing the rubber wouldn't necessarily change the characteristic of the cars tendency to understeer, but would allow more cornering speed before doing so
3rd Nov, 2006 at 07:32:33am
I agree with above but I just thought understeer when pushed was standard on all 4WDs to a certain degree. On 7th Nov, 2008 Nic said:
3rd Nov, 2006 at 07:53:19am
Sorry Dave, it's a Legacy. Look at it.. It's a grandma's car. They're built like that.
3rd Nov, 2006 at 08:14:52am
The problem is that it is a 4wd Subaru. That is what they do. You have to change your driving style. However, I know changing the front tyres on my 'family' car made a massive difference. With crap old tyres it would wash out, but with a decent set of boots it was much better.
http://www.twin-turbo.co.uk
3rd Nov, 2006 at 08:43:12am
On 3rd of Nov, 2006 at 08:14am Ben H said:
The problem is that it is a 4wd Subaru. That is what they do. You have to change your driving style. I think Ben has hit the nail right on the head there, it is a characteristic of the car, I found the same thing with my old Legacy until I learned how to drive to take advantage of the 4wd system. My fathers ur-quattro turbo is even worse than the subaru's for understeer due to the big heavy iron 5-pot right up front, but he certainly knows how to get the best from it after 13 years of ownership, slower in, and MUCH faster out I think is the key here.
3rd Nov, 2006 at 08:58:55am
Watching the Imprezas at Combe the other day showed how slow they are around corners. Having said that - one word Alignment - check out the forums for Scoobies and you will find that most suffer Mini probs - not set up right from new! On 5th Sep, 2011 Vegard said:
3rd Nov, 2006 at 09:28:52am
My other car used to suffer from terrible understeer, until i fitted a front strut brace, which has dramatically improved the situtation with no other mods. Wether this would help your car is a different story... |
1425 Posts Member #: 690 Post Whore Norfolk |
3rd Nov, 2006 at 10:10:14am
Dave - changing the tyres will merely increase the speed, g, at which understeer will occur - you'd need to start changing the arbs'springs etc to get the car to fundamentaly change its characteristics.
If Carling made Mini engines
3rd Nov, 2006 at 10:57:02am
3rd Nov, 2006 at 01:25:58pm
Thanks all - you confirmed my thoughts - and now allows me to figure out who REALLY doesn't know what they're talking about (on the subaru forum)....
3rd Nov, 2006 at 01:56:47pm
i can comment on 4wd but my lupo gti was crap in the wet and would under steer all the time, even at slow speeds and off the power. i changed the tyres from Dunlops to Continentals and it handles in the wet know. also general handling is better and now can over steer if provoced. when i say better, i meen much much better.
3rd Nov, 2006 at 07:16:57pm
my mate had a legacy turbo estate (like a hurse!) , a WRX estate then a STi estate.
3rd Nov, 2006 at 07:46:09pm
Well, the legacy I've got understeers a lot less than the legacy that ended in 2004 for sure... I just found it a little disapointing that the handling was this way inclined.
3rd Nov, 2006 at 07:57:09pm
"all season"
3rd Nov, 2006 at 08:40:24pm
On 3rd of Nov, 2006 at 08:58am Scruffy said:
Watching the Imprezas at Combe the other day showed how slow they are around corners. Having said that - one word Alignment - check out the forums for Scoobies and you will find that most suffer Mini probs - not set up right from new! I heard that when I went on a scooby rolling road session at powerhouse? Cheltenham.They were re aligning scoobys to there own figures
4th Nov, 2006 at 02:06:25am
your comparing to the mini dave..lol
4th Nov, 2006 at 02:47:51am
On 3rd of Nov, 2006 at 07:57pm mini13 said:
"all season" it's not one of those sodding outback's i keep seeing whenever i'm in the states is it? LOL my mates legacy was a 94 I think. No, it's the 2005 Legacy GT with the 2.5litre JDM/USA spec 300hp/lbft STi engine, albeit de-tuned for the legacy with a compressor that runs out of puff at 5000rpm... Outback? Don't make me laff. It's in the link below - after 2005 they dropped the manual trans behind the turbo motor; making these rare beasts indeed. It's crying out to be modified, but that warranty is too much to piss up the wall... http://www.turbominis.co.uk/forums/index.php?p=vt&tid=10621 Edited by turbodave16v on 4th Nov, 2006. On 17th Nov, 2014 Tom Fenton said:
6th Nov, 2006 at 08:56:15am
As a longterm Legacy driver I must be used to the way they drive, or my natural driving style suits the car. I I push it it's very neutral, followed by slight oversteer (It understeers round slow corners mind). I only have 170bhp though.
