| Home > General Chat > Non mirrage T2 set up. | |||||||
2645 Posts Member #: 1246 Post Whore Lowestoft, Suffolk. |
24th Dec, 2006 at 04:48:16pm
Couldnt find much using the search, so sorry for having to ask this. Those of you that are using a T2 on the standard metro manifold, What are you using for the exhaust elbow? All help, views, and pics very appreciated!
24th Dec, 2006 at 05:05:50pm
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=9330
24th Dec, 2006 at 05:08:20pm
So I use that plate to bolt to the T2, and then cut the elbow from the T3 and weld it on, is this correct?
24th Dec, 2006 at 05:26:24pm
No,l at least that's not what we did. Try this thread, looks the same as the other thread at the start, but it isn't
Edited by wil_h on 24th Dec, 2006. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
24th Dec, 2006 at 05:37:46pm
Thanks for that, did you get any made up in the end? Do mirage sell the elbow and down pipe seperatly, if so how much?
24th Dec, 2006 at 05:39:57pm
think the elbow is a home made joby mate, thats what im going to do anyway! My build thread..
24th Dec, 2006 at 06:10:00pm
On 24th of Dec, 2006 at 05:37pm shaneyboy said:
Thanks for that, did you get any made up in the end? Do mirage sell the elbow and down pipe seperatly, if so how much? Shane. Don't know if they sell the elbows separately but you might be able to go halves with TurboTel, as I think he only wants the manifold. http://www.turbominis.co.uk/forums/index.php?p=vt&tid=127231 Isambard Kingdom Brunel said:
![]() 4641 Posts Member #: 20 My sister is so fit I won't show anyone her picture Lake District |
24th Dec, 2006 at 06:19:55pm
I use the T2 elbow, cut, rotated and re-welded. |
24th Dec, 2006 at 07:19:26pm
Thanks for that, did you get any made up in the end? Do mirage sell the elbow and down pipe seperatly, if so how much? Shane. The only thing that got made up was the plates. because of the individual nature of the T2 on a T3 manifold, making an elbow using the plate has to be a one-off for each car. If I was making another, I'd use a 'tight' 90deg bend from Demon Tweeks to start with. I used a normal 90deg bend and it was hard work. My brother (Ben_H) will most likely getting some more plates cut in the new year for various turbos, so if you ask nicely he might get you one. He might also have some T2 ones left (PM him, or I'll ask him tomorrow). Otherwise, if you can get things like this cut, he'll be more than happy to send you the diagram. Wil Fastest 998 mini in the world? 13.05 1/4 mile 106mph
24th Dec, 2006 at 08:26:29pm
that will be an interesting conversation over the wil/ben christmas dinner table
27th Dec, 2006 at 05:54:48pm
Thanks for that guys, was hoping for an easy option tho, lol. Think i will go down the cut and weld option, Unless anyone advises strongly against it? As the elbow is cast is the only welding option tig, or can I use mig?
27th Dec, 2006 at 07:19:52pm
You can use a mig. Mine's been fitted for some 3+ years without a problem. {touch wood} |
27th Dec, 2006 at 07:35:56pm
my cast manifold is migged too, but to get decent penetration it had to be pre-heated or the weld didnt take well atall, but itll be obvious when you come to do it yourself. turbo 16v k-series 11.9@118.9 :)
27th Dec, 2006 at 10:08:32pm
If your going to mig is get it good and hot and try to weld to one edge of each piece then weld teh welds together.
27th Dec, 2006 at 10:40:00pm
when you say heat it,... like in an oven (lol) or warm it with oxy acetylene?
27th Dec, 2006 at 10:55:41pm
MIG or TIG needs heating the same, it's not the welding method (although the less local heat of gas welding makes it slightly less important) it is the relative properties of the different materials that makes the heating necessary. The cast iron won't spread the heat from the weld at the same rate as the weld pool and it will cool at a different rate also which leads to the cracking, alogn with a couple of other properties of cast iron fighting you on this one.
27th Dec, 2006 at 11:12:29pm
27th Dec, 2006 at 11:19:38pm
shaney, to be honest I am not a gas welder and have very little experience of using it on anything other than thin section steel so I can't answer that one. Somebody on here will.
27th Dec, 2006 at 11:35:52pm
Thanks for all that Roger, appreciate it, wouldnt of thought one little part would cause so much hassleLOL, buts the way it usually goes!
