| Home > Help Needed / General Tech Chat > crank problem ? | |||||||
![]() 3184 Posts Member #: 628 Post Whore a LIL fishing village on the coast - Newcastle Upon Tyne |
30th Dec, 2006 at 08:09:00pm
ok i am ready for a red face of embarassment here. I have put me pistons in the block and have put the crank on, I have not even torqued it down fully yet, and i cant get the crank to turn, iam using +10 shells it is as if they 8nt right, but they are the ones supplied by the folk that pollished the crank, i did notice that the thrusts were pretty tight, anyone any ideas ? i have plenty of lube on em. only thing i havnt done is take center strap off and turn it around, but this should not make a diff should it ?
On 17th Aug, 2009 Jay#2 said:
I doubt I'll be dipping into the 13's like you did though! |
30th Dec, 2006 at 08:25:09pm
have you mixed the order or the bearing caps up or anything i did this and it made a difference.
Edited by Carl on 30th Dec, 2006. no longer a series, but still 1.3 turbo.
30th Dec, 2006 at 08:34:01pm
the mains are all matched i sent the center one away to get machined so i could put the strap mod on. and i stamped all my rods and endcaps prior to removal. Will pop out the thrusts, just wanted to ask before i pulled it to bits as all, if it turns out to be the thrusts i am at a loss of how i will sort it, i thought the thrusts were all one size. Edited by Richie on 30th Dec, 2006.
30th Dec, 2006 at 09:12:57pm
I'm sure someone else posted a similar question a while back (I'll have a search and see what I can come up with) but have you tried assembling the rotating assembly without the piston rings? I'm wandering if it could be an issue with the ring gap. Isambard Kingdom Brunel said:
30th Dec, 2006 at 09:19:38pm
Found the thread I was thinking of:
30th Dec, 2006 at 10:11:30pm
the compression ring / top ring have 13 thou clearence, i have tried taking the rods off the crank and pushing them up the bores, then trying the crank again, but there is no change
30th Dec, 2006 at 10:20:21pm
have you had the crank ground to .010. or is it at standard.?? |
30th Dec, 2006 at 10:35:46pm
Sounds like you need to take a step back and think about it logicaly.
31st Dec, 2006 at 12:21:39am
the crank was ground +10 and the shells were provided by the engineering firm to match the crank, i have already tried taking the thrusts out and still no difference, all shells seated correctly, and all caps etc are correct way and are the ones for the block so to be fair slater i have tried to narrow it down, hence why iam now scratching my head asking the lads if they can think of anything else.
31st Dec, 2006 at 12:42:10am
31st Dec, 2006 at 10:19:45am
I can only think off two possible options;
On 31st of Dec, 2006 at 12:21am my first turbo said:
the crank was ground +10 and the shells were provided by the engineering firm to match the crank I know it's a bit of a pain, but your probably best taking the crank, shells & block back to the company that did the machining. As you might have guessed I clutching at straws here, but I hope it's of some help. Isambard Kingdom Brunel said:
31st Dec, 2006 at 10:47:52am
I think Slater is right here, there is a bit more of an investigation needed.
31st Dec, 2006 at 11:09:51am
TRY THIS ITS SIMPLE!!
Edited by MikeRace on 31st Dec, 2006. 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
31st Dec, 2006 at 12:15:27pm
eureeka ! 1573 spot on cheers, the lugs were slightly off (fucked) so the cap was pulling slightly off and causing it to nip the crank, i have never heard of this problem before ?
31st Dec, 2006 at 12:36:31pm
No probs
31st Dec, 2006 at 01:39:31pm
WAHOO!!! |
31st Dec, 2006 at 02:14:53pm
Perhaps they ground the crank 0,10mm(approx .004") then supplied .010" bearings
