| Home > Help Needed / General Tech Chat > Please help me decide which pistons to get (and what CR) | |||||||
76 Posts Member #: 61 Advanced Member |
9th Jan, 2007 at 09:48:54pm
I need to get my block rebored and trying to decide which pistons to get.
9th Jan, 2007 at 10:09:12pm
id say the 'sensible' option would be to go with the +20's, that way you can rebore the block to +40 next time, and have a lower cr for a bit more safety regarding boost.
9th Jan, 2007 at 10:40:47pm
9th Jan, 2007 at 11:23:48pm
On 9th of Jan, 2007 at 09:48pm Jonas said:
It looks like the MiniSpares Mega pistons is out of the question (these are the ones I was going to order before I did the calculations!). I must be missing the point here - but the Pistons that Morspeed machine out to 13cc are the very minispares Mega pistons you say you can't run??? In short, the MINISPARES mega pistons are strong, cheap, and easilly machine out to what you're looking for. You only go for +040 if your block needs it IMO - If it'll clean up at 20-thou, stick with that. Not sure what machining rates are like where you are, but it could work out to buy direct from minispares (don't forget to ask for your Turbominis discount 8-) ) and machine them locally. I recall Morspeed only charge 35 pounds or similar to machine them though, which is pretty good value all said and done. *****TD edit***** Please see this topic for up-to-date info on the suitability of the minispares 'mega' range of pistons for turbo use: http://www.turbominis.co.uk/forums/index.php?p=vt&tid=255230 Edited by turbodave16v on 17th Nov, 2008. On 17th Nov, 2014 Tom Fenton said:
10th Jan, 2007 at 01:09:57am
Check your deck height...
Edited by Turbo Tel on 10th Jan, 2007. website:- http://www.terryhunt.co.uk
10th Jan, 2007 at 02:30:24am
It looks like the MiniSpares Mega pistons is out of the question (these are the ones I was going to order before I did the calculations!). I think jonas means the ("from original tooling"--Hepolite?) +40 9cc pistons that are available at minispares they call them mega but think its just that they use the same ringset. (Avonbar has them as well) If so AND if I am correct on the piston height I get 8.9 CR for your head, jonas website:- http://www.terryhunt.co.uk
10th Jan, 2007 at 10:37:16am
"I must be missing the point here - but the Pistons that Morspeed machine out to 13cc are the very minispares Mega pistons you say you can't run???"
10th Jan, 2007 at 02:32:37pm
Morspeed purchase pistons from minispares in 6cc dish form. ie:
10th Jan, 2007 at 05:42:41pm
On 10th of Jan, 2007 at 02:32pm TurboDave said:
The minispares +040" 'turbo pistons' are 'new old stock' AE Turbo pistons I believe. Thats what I believe as well, if you look at one of the photographs on the minispares site it has the AE Hepolite part number 22357 stamped on it, the same part number that Avonbar use. This also brings up the point that Morspeeds "13cc Mega" and their "13cc 21253" have different crown heights so would give different CR's Talk to Simon at Morspeed, perhaps he can machine out just what you want instead of the whole 13cc?? Terry terry website:- http://www.terryhunt.co.uk
![]() 70 Posts Member #: 854 Advanced Member Fareham, Hampshire |
10th Jan, 2007 at 09:26:06pm
Excuse the thread stealing but how much is the discount members get from minispares and can you use it online?
![]() 243 Posts Member #: 89 Senior Member Sydney Australia |
11th Jan, 2007 at 05:37:12am
I have +20 omega and i went down to 7.8:1 looking to run 16 -18psi and it is too low it is a bit dowy off cam and under 2k or so.
179hp on 12psi 1293cc of pure A series
22nd Jan, 2007 at 03:04:16pm
I have finally decided to go for Minispares Mega 6cc pistons. And machine them to the desired volume (about 10-11cc).
298 Posts Member #: 1357 Senior Member telford,shropshire |
24th Jan, 2007 at 10:37:49pm
jonas, what made you go for the 6cc mega's. im in a similar posistion and looking at the 13cc 21253's from morspeed.
'always keep a spare shot for a stray bird' |
25th Jan, 2007 at 07:52:27am
Mainly because 13cc is to much for the CR I want.
26th Jan, 2007 at 04:05:54pm
so can you use any of the mega pistons from minispares of do they have to be the turbo ones? 'always keep a spare shot for a stray bird' |
26th Jan, 2007 at 08:21:04pm
On 25th of Jan, 2007 at 07:52am Jonas said:
Mainly because 13cc is to much for the CR I want. I just asked Simon to only dish them to 11cc, I just asked him if he would do that for anybody and he says he will cut them to whatever cc you want 6-13cc. Terry website:- http://www.terryhunt.co.uk
