Home > Help Needed / General Tech Chat > fuel lines
rsroadkilla
Member #: 911
Ive used the search engine to work out i need 8mm fuel lines... but is this 8mm external measurment, or internal measurment??
cheers
Bruce
fordimus maximus
Member #: 1357
telford,shropshire
its ID my friend.
rsroadkilla
Member #: 911
id??
8mm OD is more like it....
ID - Inside Diameter OD - Outside Diameter
Minimad69
Member #: 1311
Yeovil, Somerset
The inlet to the turbo fuel regulator is 6.7mm ID if i remember correctly so 8mm ID fuel pipe is pointless
fordimus maximus
Member #: 1357
telford,shropshire
sorry, im sure i read somewhere that it was ID. listen to these guys they know a hell of alot more than me.
good job was going to by my fuel lines this week.
fordimus maximus
Member #: 1357
telford,shropshire
ive found this.
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=10564
danboy
Member #: 1381
I don't think it's that critical as long as it's greater than 6mm as all the fuel the engine needs has to pass through a hole less than 3mm diameter at the needle valve.
As long as the pump has adequate capacity that is
Regards
Dave
Edited by danboy on 21st Jan, 2007.
at the minute i use some 8mm ID rubber hose as its cheap until i can "borrow" some lengths of stainless from work and fit them properly to the car!
*smiley*
Minimad69
Member #: 1311
Yeovil, Somerset
Basically as long as the return fuel line is greater ID than the supply line to make sure there is no restriction it will be ok.
The return from the fuel regulator outlet is 6.7mm ID so a restrictor of 6.5mm or so should be placed in the supply line just before the inlet to the regulator.
You can use 8mm ID or 8mm OD fuel pipe it wont make any difference as the restriction is at the fuel regulator
If im wrong then please someone correct me *smiley*
Not sure I agree.
Im using a 1/2" feed on my V8, and a 3/8 return with no problems.
Although in general, I see no reason why not to have both the same size. It just suited me from a packaging point of view.
On my Mini, I used 8mm rubber hose for both feed and return, although I think the actual return fitted to the tank was only 1/4"
I would safely say that an 8mm OD hardline tube for a feed, and a decent efi style pump, will be more than adequate for ANY Mini engine.
Some people have had problems with the return being too restrictive causing as back pressure in the return.
This upsets the regulator which causes over fuelling if IIRC.....
I think this is the reason most go for 8mm feed and return.
Basically as long as you can get the pressure to the carb low enough then it shows that the return is free flowing enough.
*smiley*
Minimad69
Member #: 1311
Yeovil, Somerset
I spose as long as the feed and return are the same size and theres no restriction there shouldnt be a problem as the amount of fuel being returned from the regulator will always be less than the supply
danboy
Member #: 1381
Can't see what the problem is.
Keep inlet and return the same diameter as there is always less flowing in the return (inlet flow minus carb requirement)
Regards
Dave
Looks like you just beat me to it MM69
Dave
rsroadkilla
Member #: 911
so i need 8mm OD fuel lines. :)
Cheers people :)
