| Home > Technical Chat > Flywheel torquing up proceedure | |||||||
982 Posts Member #: 97 Post Whore Near Daventry, midlands |
9th Feb, 2007 at 09:29:36am
Im just curious to find out how some of you chaps torque up your flywheels? Obviously your putting a massive whack more torque through them than stock.
9th Feb, 2007 at 09:41:23am
1425 Posts Member #: 690 Post Whore Norfolk |
9th Feb, 2007 at 09:52:43am
I lap the tapers with fine paste, then clean off with thinners, repeat until all contact area is grey. I use EN24 keyed washer and bolt. Then small dab of thread lock on bolt and a tiny smear of oil under the head of the bolt - then torque up without lock tab to 170/180 lb/ft.
If Carling made Mini engines
9th Feb, 2007 at 02:46:43pm
Lap, clean with acetone, pop in oven, heat to 180-degrees, drop on (with keyed wahser to locate), give a whack, then quickly wind the bolt in and torque up to 150 lb.
9th Feb, 2007 at 04:27:41pm
LOL, Does it actualy come off when you do want it to? On 26th Oct, 2004 TurboDave16v said:
9th Feb, 2007 at 04:32:33pm
809 Posts Member #: 224 Post Whore Katy TEXAS |
9th Feb, 2007 at 04:36:02pm
On 9th of Feb, 2007 at 04:27pm Mini Sprocket said:
LOL, Does it actualy come off when you do want it to? Thats what I thought lol You forgot to mention the part about the electron beam welding Dave lol
9th Feb, 2007 at 04:45:54pm
All Ive ever done is,
9th Feb, 2007 at 05:19:11pm
well the last I did the same as you matty...
AlexF |
9th Feb, 2007 at 05:45:31pm
i do the same as TD,
9th Feb, 2007 at 06:07:49pm
On 9th of Feb, 2007 at 05:19pm AlexF2003 said:
well the last I did the same as you matty... and it came loose! The flywheels was on there good and proper - but the bolt was only just tight!! It came off normally though - I guess I was lucky lol. Alex Strange!!!!
The last two times ive done mine Ive had to get a heat gun on it, and leave the puller on over night before it budges? The time before that I snapped the puller. Lol I must of been made of some cheap monkey metal! https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
9th Feb, 2007 at 06:55:08pm
i just do it as per the haynes |
9th Feb, 2007 at 10:01:21pm
On 9th of Feb, 2007 at 05:45pm mini13 said:
i do the same as TD, I find this gets them off.
![]() My, that is a well engineered hyraulic puller
I want one
9th Feb, 2007 at 10:06:05pm
the tab washers are made of monkey metal and should be binned as they will yield under the torque applied allowing the bolt to lose tension - leaving the potential for the flywheel to fret - thread locker is a much better engineering solution. If Carling made Mini engines
9th Feb, 2007 at 10:54:19pm
Cheers Sprocket. On 28th Aug, 2011 Kean said:
10th Feb, 2007 at 10:02:52am
I was reading Frost on the bog the other day and saw that their cheapo clarke grease gun was good for 345 bar, i thought it was a misprint! "Turbo's make torque, and torque makes fun"
10th Feb, 2007 at 11:23:03am
I re-drilled my flywheel and made my own 6 bolt puller
10th Feb, 2007 at 12:17:59pm
350 bar is about 5000 psi, that sounds about right for the spec's i have seen for the cheap aluminium ones, the steel ones (only a couple of quid more) normally quote about 10000 psi.
