Home > General Chat > Mirage and Lambda
Who has a lambda sensor on their mirage manifolds?
Did Mirage fit the boss or did you get it fitted yourself?
I usually do them myself on mild tube, but I can't weld stainless withiout ruining it an don't want to harm any guarantee.
Ant news on production of the manifolds.
Wil
Edited by wil_h on 20th Feb, 2007.
Brocky
Member #: 224
Katy TEXAS
Wil
Looks like Iains the man to ask ?
feeble has one too that mirage had put on for him
Brocky
Member #: 224
Katy TEXAS
Wil,
Could you put it in the down pipe (if mild steel) just below the elbow ?
or does it need to be close to the turbo ?
Excelent.
When orders are being taken again, I'll get one put on.
Nick
Member #: 154
Midlands
i know keans got his wideband lambda in his link pipe and it works fine cos he didn't fancy welding onto his mirage manifolds.
danboy
Member #: 1381
For a wideband lambda sensor to last any amount of time it needs to be kept below 800 degrees celsius.
It is generally considered necessary to mount it at least 0.5 mtr after the turbo.
I would think the optimum would be to mount it somewhere around the bottom bend of the down pipe possibly with an access hole in the floor.
Regards
Dave
I do
Rich fitted it, I made the crappy actuator bracket
clubminiflip
Member #: 54
nr coventry
i had feebles mirage kit from him & the boss for the sensor is in the same position as 'british open classic'
danboy
Member #: 1381
Don't want to keep banging on but if you want your wideband sensor to last have a look at the warnings at the bottom of this page.
http://wbo2.com/lsu/default.htm
I am pretty sure it will be far too hot at the position shown.
Regards
Dave
My narrow-band unit live in my cast elbow without probs for many years - but I wasn't about to risk my pretty Wideband unit LOL!
This now sits (horizontally) in the downpipe, at a point in line with the two holes in the rear 'mouts outriggers' on the front subby. This is a good place for it - out of the way of damage from the road and far enough away from the turbo (i feel) to avoid damage.
Great info, i'm using a narrow band though.
Star Mag
Member #: 375
Leicestershire
Danboy you using the techedge kit?
danboy
Member #: 1381
No. Innovate
Regards
Dave
Mine would of been better further away in hind sight but at the time i didnt know a lot better. sure it will be fine *smiley*
Probably replace mine with a plug once the engines in tune and i feel confident of it.
In fear of dragging up an old thread I'll still do it:
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=1010
So WTF is going on Dave? You're like a politician :)
danboy
Member #: 1381
Vegard, TD is not doing the politician thing. Basically the difference in position is due to using two different Lambda sensors, narrow band and wide band.
The max temp on the wide band is more critical to avoid damage.
The narrow band, especially early ones needed exhaust heat put into them to operate and are generally mounted closer to the exhaust port face.
Regards
Dave
PMSL
Regards
Dave
Bla bla bla. Dave is right again, Vegard is stupid, been there done that bought the T-shirt etc....
Wil, if you need a tap for the lambda sensor, I have one you can borrow.
danboy
Member #: 1381
I had better start posting bullshit then eh! (lol)
Seriously it's not the intention to make you look stupid and I apologise if you think I did.
As your avtar states " I pick holes in everything". I suppose I must be a little like you.
I relly hope we will not fall out over this as I respect what you have to say on this and other related forums and what you are doing with your Mini,s.
Once again sorry if I offended you, It was NOT my intention
Regards
Dave
Dave, V's a bit more hardy than that arent you V?
*smiley*
He gives and takes so i've heard *happy*
I've given little lately to be honest. Unfortunately *wink*
Danboy: I'm never offended.:)
jamesfawcett
Member #: 218
Bingley, West Yorkshire
heres a pic where mine was
yeah mirage welded it in for a tenner
dn89mini
Member #: 1506
Cheshire
Any idea when these will be available again to buy?
Check out the (slow) progress at.......
http://www.turbominis.co.uk/dn89mini
