| Home > Help Needed / General Tech Chat > First Engine Build | |||||||
108 Posts Member #: 654 Advanced Member |
26th Feb, 2007 at 08:35:50pm
Hi, I have been browsing these forums for a while now collecting info on the turbo conversion, and I am now at the stage where i need to decide what engine spec to go for.
26th Feb, 2007 at 09:08:34pm
Just turn the boost up a bit .... that is cheapest.
26th Feb, 2007 at 09:08:47pm
For that sort of BHP, all you will need is a tad more boost and an intercooler. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
26th Feb, 2007 at 09:10:18pm
26th Feb, 2007 at 09:16:48pm
Thanks for the quick replies, so what kinda boost can the standard compression ratio take? or will fitting an intercooler do the trick for the sort of power im after. Also straight cut gears were mentioned, I'd like to avoid this route if possible, as it aint so cheap, what kinda gearbox mods could i get away with? centre main strap, centre oil pickup be ok?
26th Feb, 2007 at 09:20:48pm
well i know a bloke with a standerd metro turbo lump in his mini running 10psi with out an intercooler!
My build thread..
26th Feb, 2007 at 09:24:27pm
A well rebuilt box can handle around 140bhp spec (it's the torque that kills them, especially in first).
26th Feb, 2007 at 09:25:48pm
Hmm how long will that hold out though? If im shelling out for a rebuild I want something reliable, and driveable, hmmm t3 driveable?, anywho cheers for the posts, got some options to take, like the sound of the almost free upgrades though... |
26th Feb, 2007 at 09:28:43pm
I did well over 20k miles with the engine in that spec with only a rebuilt standard box (well done) and a 4 pin diff.
26th Feb, 2007 at 09:34:10pm
Yer 4 pin diff was gonna go in, i've heard minisports should be avoided for the diff... think I might go for summet like that, hows this sound
26th Feb, 2007 at 10:09:51pm
Centre main strap is worth doing for the little it costs. Centre oil pick up is a MUST. Oil cooler probably unneccesary, fit a gauge first.
54 Posts Member #: 1425 Advanced Member Yorkshire Wolds |
27th Feb, 2007 at 07:16:43am
Hi Kav, Thanks to the huge help from members of this forum I managed to build a similiar sort of engine (my first Turbo) which gave the power figures you are after, and built with reliabilty in mind have a look at http://www.turbominis.co.uk/forums/index.php?p=vt&tid=139114
27th Feb, 2007 at 05:55:30pm
Hi thanks for the support roadrocket, your setup sounds like the kind of thing i'm looking for, you mentioned you increased head capacity to 29cc, what compression ratio does this give you, also what size valves are those?
27th Feb, 2007 at 06:44:29pm
Hi mate not accurate on the comp ratio mate Im affraid but I believe its near 8.8:1
Edited by Roadrocket on 27th Feb, 2007. |
27th Feb, 2007 at 10:09:45pm
Thanks that helps alot, the only thing confusing me now is wether to mod my std turbo head or not, if your getting that kinda power at 4psi, then without the modded head and just the n/a cam with 8ish psi I might be able to hit the same kinda figure, but then again I suppose u lose some driveablity off boost...
27th Feb, 2007 at 10:16:59pm
Oh BTW the only reason iIm leaning away from differant valves is that the std has the sodium filled exh. one's are these worth working around, or do they make little or no differance, also did you get the 3 angle valve seats done?
28th Feb, 2007 at 07:18:03am
Best thing to do is do a search in Turbominis Forum regarding the sodium filled exhaust valves. I originally asked the same question before I replaced our Turbohead for the N/A stage 3 head. I believe the MS3 head did come with 3 angle valve seats. |
28th Feb, 2007 at 01:26:35pm
IMHO, no need to lower the CR if you want 100-110BHP, as its a bit of give and take...take more out of the head give more boost... Lol
28th Feb, 2007 at 05:58:38pm
thanks for the reply, what kind of power were you getting, obviously not needed to seriously mod my head would cut down on costs, so atm ive decided on minispares cross pin diff, rs intercooler, 2 core radiator, bleed valve, dump valve (any reccommended for this kinda spec?
