| Home > Help Needed / General Tech Chat > Running lean when on boost. | |||||||
![]() 608 Posts Member #: 1106 Post Whore Hungerford, Berks |
14th Apr, 2007 at 02:52:27pm
Just after Christmas we fitted a megajolt unit to the turbo mini. We have also just installed a new jet. We also fitted a new turbo back in september. The car was running very well, but to be on the safe side we wanted it tuned. So today, now that there is some spare cash, we took the car for a RR session in cheltenham.
’77 Clubman build thread
14th Apr, 2007 at 02:55:09pm
keeping lopping some off that needle.
14th Apr, 2007 at 03:05:00pm
That was our first thought so we checked the fuel pressure. It is rising on boost:
14th Apr, 2007 at 03:13:31pm
not always the case.
14th Apr, 2007 at 03:17:42pm
Tee-piece trick ??? On 17th Nov, 2014 Tom Fenton said:
14th Apr, 2007 at 03:57:17pm
No We have not tried the Tee-piece trick, obvious I guess. I remeber reading this before, when we had the initial probs back in the summer. I will give it a go tomorrow. Thanks For that.
14th Apr, 2007 at 07:48:02pm
14th Apr, 2007 at 08:16:52pm
As far as I know yes the gasket is correct. It does have the hole for the plenum feed to the carb. It was running fine until we took the carb off to change the jet (and I removed the balance pipe).
14th Apr, 2007 at 08:28:34pm
14th Apr, 2007 at 08:39:35pm
No, the actuator signal output on the carb is blocked off. ’77 Clubman build thread
14th Apr, 2007 at 08:51:58pm
14th Apr, 2007 at 09:02:47pm
Sorry, what I meant was the port from the carb, which is shown as item 4 on the picture from the thread below.
14th Apr, 2007 at 09:16:03pm
Edited by Bat on 14th Apr, 2007. VEMs Authorised Installer / Re-seller. K head kits now available!
14th Apr, 2007 at 09:30:47pm
14th Apr, 2007 at 09:53:28pm
well if you have plenty of fuel then all i can say is take it back and get him to lop some metal of the needle mate as this is more than litghly were the problem lies.
14th Apr, 2007 at 10:03:16pm
15th Apr, 2007 at 09:29:11am
There definately are 0.125 needle / jet combinations available. Every day is a school day ...........
15th Apr, 2007 at 09:30:22am
On 14th of Apr, 2007 at 08:16pm part time mechanic said:
As far as I know yes the gasket is correct. It does have the hole for the plenum feed to the carb. It was running fine until we took the carb off to change the jet (and I removed the balance pipe). Incidentally the jet we took out was either very worn or was the wrong jet. There appears to be a significant difference in the size. Thinking maybe the previous owner of the Metro it came out of had the same problem and used a 0.125" jet to over come the lean out problem. I have not measure the old jet yet, but I say this because it has always run rich. It only just past the MOT on emissions. Just a thought, as the size difference is significant enough to notice by eye. Going back to the Tee-piece trick: We put a gauge on the actuator signal output from the carb (the one 3/4" forward of the fuel input) and that was reading 6psi on boost. The boost gauge was reading 7psi,. Would that 1 psi difference be a problem? yes !! the port to the float chamber should allways be at least 3 psi higher reading than the boost reading ,make sure yuor fuel prsssure is 3 to 4 psi by adjusting the screw on the top of the fuel pressure regulator ,and the t piece trick should solve the prob , or you could do what i do which is connect the plenum boost taKEOFF to the connection in front of the fuel inlet ,then connect the pipe to the fpr to the stub above it on the side of the carb .. ,the one at 45 degrees.that way you dont need a t piece at all . regards robert Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
18th Apr, 2007 at 07:08:56pm
Thanks for all your help everyone.
18th Apr, 2007 at 07:18:47pm
sounds like you need a better RR operator... |
18th Apr, 2007 at 07:51:38pm
I think you are right, but we can't find anyone in this area who knows much about 'A' series turbo's.
18th Apr, 2007 at 07:53:35pm
it does help but when you get stuck its the experts that are supposed to help.
18th Apr, 2007 at 07:58:08pm
Edited by Bat on 18th Apr, 2007. VEMs Authorised Installer / Re-seller. K head kits now available!
19th Apr, 2007 at 12:53:04pm
Which RR did you use? As you say cheltenham I am assuming that you visited Mech Repairs (www.rollingroad.co.uk), is that correct??
19th Apr, 2007 at 01:02:50pm
Go see peter baldwin :) |
