| Home > Help Needed / General Tech Chat > 1293 compression help | |||||||
69 Posts Member #: 1457 Advanced Member Bristol |
14th May, 2007 at 07:52:15pm
Hi, am building up a 1293 turbo engine (yet to be re-bored) but need advice on what pistons i should use to achieve the correct compression ratio. The head is standard turbo with slight port work. Could anybody tell me what sort of compression ratio i would get using the omega 10cc dish pistons from avonbar? Or advise me on what i should use? Want to order parts this week as want to get it re-built asap so any advice/ answers would be aprreciated. Thanks |
14th May, 2007 at 07:53:58pm
It depends on what sort of boost/hp you plan on running.
14th May, 2007 at 08:10:49pm
Guessing around 10psi, car will only be used on weekends just want it for fast road use, shows etc. |
14th May, 2007 at 08:29:44pm
147 Posts Member #: 814 Advanced Member Utrecht, The Netherlands |
14th May, 2007 at 09:12:07pm
The standard pistons are virtually bullet proof (there is a post with pictures, do a search) although if i'm correct they are not available in the first +20 oversize..
