| Home > Help Needed / General Tech Chat > having trouble starting | |||||||
![]() 2054 Posts Member #: 452 Post Whore Chester, UK |
24th May, 2007 at 11:28:51am
Ok well the situation is this.
24th May, 2007 at 01:22:30pm
Smells to me like an incorrect connection n the starter solenoid, can you post up a picture of how you have it connected. |
24th May, 2007 at 01:46:06pm
hi,
24th May, 2007 at 04:54:47pm
25th May, 2007 at 10:00:40am
On 24th of May, 2007 at 04:54pm Bat said:
Hi, 1, Unplug the alternator, see if that fixes the ignition lights on without the key. 2, Check the earth cable on the battery. 3, Try bridging the 2 studs on the sol with a big spanner see if it turns over. Cheers, Gavin :) thanks gav for help 1, will this do anything. if it does whats the initial problem? 2, this is brand new so i think is ok. 3, i done this but we think there maybe some internal issue with the starter whereby it has enough power to turn it over out of the car but inside its to week to do anything. |
25th May, 2007 at 05:42:54pm
