| Home > Help Needed / General Tech Chat > electric water pumps, | |||||||
26th May, 2007 at 06:58:43pm
i need to search through any threads on the subject , but dont know how to use search facility,
Edited by fastcarl on 26th May, 2007. |
26th May, 2007 at 07:02:13pm
You useless northerner
Edited by paul wiginton on 26th May, 2007. I seriously doubt it! |
26th May, 2007 at 07:04:42pm
26th May, 2007 at 07:16:23pm
Hi Carl,
144 Posts Member #: 1677 Advanced Member Netherlands, The Hague |
26th May, 2007 at 09:42:04pm
1 of the pro's of electric water pump is that you can leave it running with a little help from a turbo timer after you turn off the engine. Another plus is that a electric pump always performs in the same manner. There is no to fast or to slow in combination with revolutions of the engine.
26th May, 2007 at 09:54:11pm
how reliable are they though?
My build thread..
26th May, 2007 at 11:09:40pm
Ive run one for a couple of years and find it great. Its a Bosch canister type pump similar to the KAD item. They are used believe it or not in coffee vending machines.
27th May, 2007 at 10:56:06am
Paul, Have you got the Bosch part number Please.
27th May, 2007 at 12:27:09pm
Ill have a look later.
27th May, 2007 at 03:07:33pm
hmm, they've just changed all the vending machines at work... |
27th May, 2007 at 07:31:53pm
Here is my pump
Edited by paul wiginton on 27th May, 2007. I seriously doubt it! |
27th May, 2007 at 07:53:45pm
Cheers Paul, I will see if I can find some technical info on this and post it up.
27th May, 2007 at 08:24:46pm
you may have to type it in as 0 392 020 061 to get any hits. I think the pipe ends look a bit small to flow enough easily? I have just bought a meziere pump, it weights a bit and is a bit bigger than these pumps ( I have one like that here too), but it flow around 80 litres a minute and is made specifically for the purpose (does not only give flow, but is also able to build some pressure), and has the pipe end size you wish. Cost me around 100 quid. I would uesstimate that the pump pictured flow around 20 litres a minute without any head. Edited by miniminor63 on 27th May, 2007. |
27th May, 2007 at 09:04:28pm
Nope! it does 60 litres per minute. Checked this myself. Its been on my car for a couple of years and is very good.
27th May, 2007 at 11:41:40pm
http://www.boschmotorsandcontrols.co.uk/el...20064/index.htm
28th May, 2007 at 07:58:17am
We use these pumps at work on the Twin Supercharged Vantage. There are 2 as standard to run the charge coolers. We fit a 3rd to gain another 50 hp making 600 and nearly 600 lbft.
28th May, 2007 at 10:49:00am
cool. On the Mercedeses they are used for pumping water to the AC/heater usually. |
28th May, 2007 at 12:59:17pm
paul have you got rid of the mechanical pump? or is the electric one used as a secondary pump?
My build thread..
28th May, 2007 at 05:16:09pm
The mechanical waterpump is gone, its just the canister type electric pump
784 Posts Member #: 912 Post Whore North Yorkshire |
9th Jun, 2007 at 02:16:36pm
Can you have a look at this and tell me if it will do.
I drill holes in everything..! |
10th Jun, 2007 at 10:46:15am
another car i found one on is a leon cupra R. havent checked it full but noticed it on a mates last weekend. |
