| Home > Help Needed / General Tech Chat > Ignition warning light | |||||||
158 Posts Member #: 551 Advanced Member Ashington W.Sussex |
22nd Sep, 2007 at 08:59:41am
Hi
22nd Sep, 2007 at 12:26:36pm
2646 Posts Member #: 1246 Post Whore Lowestoft, Suffolk. |
22nd Sep, 2007 at 07:46:56pm
Cant resist saying this so sorry in advance! TAKE THE BULB OUT!
23rd Sep, 2007 at 02:30:08am
NOOOOOOO
23rd Sep, 2007 at 07:47:40am
Can you show us pictures of the plug in the alternator and the back of the speedo?
I seriously doubt it! |
23rd Sep, 2007 at 09:21:35am
Hi Paul
23rd Sep, 2007 at 10:20:34am
No! There should be positive feed from the alternator and the other spade goes to earth. ( Atleast thats how mine is)
23rd Sep, 2007 at 10:55:30am
194 Posts Member #: 1297 Advanced Member Sunny Stockport |
23rd Sep, 2007 at 11:17:27am
Rich,
23rd Sep, 2007 at 08:32:10pm
Hi
23rd Sep, 2007 at 08:46:51pm
23rd Sep, 2007 at 08:50:33pm
Gavin
23rd Sep, 2007 at 08:58:12pm
Rich,
23rd Sep, 2007 at 09:05:20pm
23rd Sep, 2007 at 09:06:25pm
Hi Neil
23rd Sep, 2007 at 09:18:17pm
Rich,
23rd Sep, 2007 at 10:27:06pm
Mine has never worked since fitting the dihatsu alternator, but it does stop charging if i take out the bulb
23rd Sep, 2007 at 10:43:46pm
Not sure what the Haynes manual says but yes, ignition feed to one side of the bulb and the other side to alternator. |
23rd Sep, 2007 at 10:46:54pm
Nic,
23rd Sep, 2007 at 11:30:56pm
so the dash light is in effect earthed through the (live) alt. out?
23rd Sep, 2007 at 11:54:44pm
24th Sep, 2007 at 10:11:04am
If the 12V feed is coming from the regulated side of the regulator I assume the alt will not turn on properly - hence the light not go out? |
1050 Posts Member #: 764 Post Whore Staffordshire |
24th Sep, 2007 at 10:23:48am
slighty off topic, but if your were to put a switch on the ign live wire to the bulb, would that effectivly give you an alternator that you could "switch off" to gaining a couple more horses?
24th Sep, 2007 at 08:52:29pm
