| Home > Technical Chat > Exhaust Gas Back Pressure | |||||||
19th Nov, 2007 at 01:35:09pm
This subject came up last week whilst discussing Rimflow Valves.
19th Nov, 2007 at 02:03:31pm
This is exactly the thinking behind the VNT25 I am fitting on the 7 porter,
Edited by Joe C on 19th Nov, 2007. On 28th Aug, 2011 Kean said:
19th Nov, 2007 at 02:51:48pm
This was one of pete/mini1071/magazines favorite subjects. iirc, he reckoned he achieved it with a T3 using a fancy head and manifold.
19th Nov, 2007 at 02:53:07pm
I can remember him talking about this, I found it very interesting and asked how one would go about achieving it, never heard anything back.
19th Nov, 2007 at 03:06:41pm
It is mentioned in corky bells book too, doesent give any details though,
![]() 6753 Posts Member #: 828 Post Whore uranus |
19th Nov, 2007 at 06:35:12pm
On 19th of Nov, 2007 at 01:35pm Paul S said:
This subject came up last week whilst discussing Rimflow Valves. I was under the impression that it would be possible to achieve maximum boost without EGBP rising above boost pressure. Apparantly this is not the case and this has led me to consider the science in a bit more detail. i think it can be the case with a narrow power band . It started the other week when i was trying to read some turbine maps: Now the energy in the exhaust gas is nearly three times that at the inlet, based on 850 deg C temperature. how do you include the dynamic energy in the calcs for this statement paul ?oh and also the inertial suction effect on the other side of the turbine .? If the turbine and compressor efficiencies are both 70%, you have an overall efficiency of 50%. Hence you should only need twice the energy in the exhaust gas to spin up the turbo, without the EGBP exceeding boost. So why is this not the case? My theory is that the A/Rs in use are a bit on the low side so that the boost comes in early. this is what i was saying in the rimflow thread ,the smaller the a/r the higher the bp at some point ,but , if the engine is only used predominantly below the crossover point on ip versus exp ,then in reality the engine sees exp lower than inp most of the time . The flow through the turbine nozzle is limited by the speed of sound. why? Once it reaches Mach it cannot go any faster and this will cause the EGBP to rise without any further benefit to the engine. So, I was thinking that maybe we should fit a second wastegate, activated by EGBP that will prevent it going too high. if you get an increase in bp that is needing a second wastegate to bled it off ,then first you would get an uncontrollable increase in boost first, if you use a ex p take off for the wastegate ,the boost rises ,then drops and the max rpm boost is usually lower than max torque boost ,so you get a weird hump shaped boost curve.audi used this in the 100 i think . Any thoughts???? i think that ex pressure is a bit like choosing a cam or a head port design or cr ...you choose the design depending on what you want from the engine , the turbo manufacturer has designed 4 of 5 a/r housings to give you a choice ,and you choose the one if you can to create the boost curve you want ,like with a cam ,bottom end mid range top end etc , same as .47.55.68 a/r etc , if you see what i mean ,. i think this is why theres little info on this ,cos its all matched to the compressor at the design stage .:)gosh ranting on a bit time for my medicine. Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
19th Nov, 2007 at 06:48:32pm
This subject came up last week whilst discussing Rimflow Valves. I was under the impression that it would be possible to achieve maximum boost without EGBP rising above boost pressure. Apparantly this is not the case and this has led me to consider the science in a bit more detail. i think it can be the case with a narrow power band . It started the other week when i was trying to read some turbine maps: Now the energy in the exhaust gas is nearly three times that at the inlet, based on 850 deg C temperature. how do you include the dynamic energy in the calcs for this statement paul ?oh and also the inertial suction effect on the other side of the turbine .? If the turbine and compressor efficiencies are both 70%, you have an overall efficiency of 50%. Hence you should only need twice the energy in the exhaust gas to spin up the turbo, without the EGBP exceeding boost. So why is this not the case? My theory is that the A/Rs in use are a bit on the low side so that the boost comes in early. this is what i was saying in the rimflow thread ,the smaller the a/r the higher the bp at some point ,but , if the engine is only used predominantly below the crossover point on ip versus exp ,then in reality the engine sees exp lower than inp most of the time . The flow through the turbine nozzle is limited by the speed of sound. why? Once it reaches Mach it cannot go any faster and this will cause the EGBP to rise without any further benefit to the engine. So, I was thinking that maybe we should fit a second wastegate, activated by EGBP that will prevent it going too high. if you get an increase in bp that is needing a second wastegate to bled it off ,then first you would get an uncontrollable increase in boost first, if you use a ex p take off for the wastegate ,the boost rises ,then drops and the max rpm boost is usually lower than max torque boost ,so you get a weird hump shaped boost curve.audi used this in the 100 i think . Any thoughts???? i think that ex pressure is a bit like choosing a cam or a head port design or cr ...you choose the design depending on what you want from the engine , the turbo manufacturer has designed 4 of 5 a/r housings to give you a choice ,and you choose the one if you can to create the boost curve you want ,like with a cam ,bottom end mid range top end etc , same as .47.55.68 a/r etc , if you see what i mean ,. i think this is why theres little info on this ,cos its all matched to the compressor at the design stage .:)gosh ranting on a bit time for my medicine. I have not included the dynamic effects because the gas velocity at the exhaust is much higher which adds even more energy. I was just using temperature as this is the main component. There is enough energy in mass flow, temperature and velocity without having to suffer high pressure. You cannot push anything higher than the speed of sound without using significantly more energy. Remember aircraft trying to break the sound barrier in the 60s? The second wastegate would be a controlled device to limit EGBP. done properly, there should be no surges. Agree that choosing the A/R is just another tuning decision but if you select the lower A/R then it would be simple to limit EGBP with another wastegate. I think that VNT may be the answer because effectively all VNT does is vary the A/R through the load range to optimise boost without raising EGBP. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
19th Nov, 2007 at 07:06:22pm
yes i agree,, i have one in the post as we speak !! Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
3596 Posts Member #: 655 Post Whore Northern Ireland |
19th Nov, 2007 at 07:36:17pm
Perhaps just aim for larger A/R's, and larger compressors.
16 Posts Member #: 2130 Member newhaven |
9th Dec, 2007 at 11:21:21pm
really hate the use of acronyms. The standard method of use is to use the real words first then the acronym later. Really helps learners like myself.
9th Dec, 2007 at 11:36:42pm
or use google/search finction/ or jsut ask to find out what the acronyms mean, no-one will bite! and theres certainly no shame in asking. in paulS's post above for example he would have to type "exhaust gas back pressure" three times in full and "Variable Nozzle Turbine" out twice. when typing a post this saves alot of time and meens the discusstion can progress at a faster rate. aside form the fact typing it out in full is jsut annoying. :)
Edited by evolotion on 9th Dec, 2007. turbo 16v k-series 11.9@118.9 :)
9th Dec, 2007 at 11:41:40pm
On 9th of Dec, 2007 at 11:21pm 64woody said:
really hate the use of acronyms. The standard method of use is to use the real words first then the acronym later. Really helps learners like myself. But I really love turbos, especially now I know where the pipes go on the SU carb. Am i missing something here, or are you moaning that members of the board are using a/r, vnt, and other such regular (on this board anyway) abreiviations??? Theres no way people are going to type the full word out on each post just for some newbie If you dont know what some thing means go to google or wikipedia and look it up If you want people to do as i think your suggesting, i suggest you go to wikipedia and start with BAC |
9th Dec, 2007 at 11:42:17pm
damn you beat me to it |
10th Dec, 2007 at 12:05:55am
Robert, what turbo are you going for now? and can you let me know before the masses so I can buy up some before the eBay prices go the way of the GT17. Edited by Rob H on 10th Dec, 2007. Isambard Kingdom Brunel said:
10th Dec, 2007 at 12:21:36am
Edited by Bat on 10th Dec, 2007. VEMs Authorised Installer / Re-seller. K head kits now available!
10th Dec, 2007 at 09:21:46am
On 10th of Dec, 2007 at 12:05am Rob H said:
Robert, what turbo are you going for now? and can you let me know before the masses so I can buy up some before the eBay prices go the way of the GT17. burst out laughing,thanks for that nice start to the week rob . holset hx40 vnt ! Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
10th Dec, 2007 at 09:24:00am
I apologise if my use of acronyms has caused grief.
29th Dec, 2007 at 11:11:18am
Back on topic, As no one seems certain as to the relationship between Boost pressure and Exhaust back pressure I thought of a simple way to find out.
29th Dec, 2007 at 01:30:45pm
cool gauge!
29th Dec, 2007 at 01:36:34pm
it's a fuel pressure guage from a twin engined Dakota.
Edited by danboy on 29th Dec, 2007. |
520 Posts Member #: 2093 Post Whore Grenoble, France |
30th Dec, 2007 at 09:46:09pm
That's why staged turbo are used (Garrett). To avoid back pressure and to not loose the boost.
std 998 A+, g295, MD266, RHF4, 109hp @0.8bar/5400rpm |
141 Posts Member #: 954 Advanced Member Fort Collins Colorado USA |
31st Dec, 2007 at 03:37:05pm
How will MPI improve VE? VE is really how much air you manage to pump relative to the engine displacement. Can't honestly see the fuel injector phasing making much difference in that. 1275 with Back Door Turbo |
31st Dec, 2007 at 05:42:29pm
On 31st of Dec, 2007 at 03:37pm fortfun said:
How will MPI improve VE? VE is really how much air you manage to pump relative to the engine displacement. Can't honestly see the fuel injector phasing making much difference in that. Because there is no carb which is a restriction by its definition. std 998 A+, g295, MD266, RHF4, 109hp @0.8bar/5400rpm |
