| Home > Technical Chat > What compression? | |||||||
![]() 59 Posts Member #: 2176 Advanced Member |
5th Jan, 2008 at 09:26:53pm
hi guys i am new to the forum, and i have aquestion i don't know if anyone can help me?
1300 Posts Member #: 829 Post Whore essex |
5th Jan, 2008 at 09:34:18pm
the best thing to do first is do a search on compression or pistons c/r :) 1293 Turbo mini
5th Jan, 2008 at 09:51:35pm
6th Jan, 2008 at 05:40:15pm
ah i see is there anyway of finding out what PSI a bini supercharger puts out? |
6th Jan, 2008 at 05:45:48pm
On 6th of Jan, 2008 at 05:40pm V700BEN said:
ah i see is there anyway of finding out what PSI a bini supercharger puts out? Superchargers generate boost as a result of trying to force more air into a smaller space. Hence the boost is a function of the air flow generated by the charger and the capacity of the engine to which it is applied. Find out what the ratio of the pulleys is and use the sprintex calculator. This will also tell you what boost with the 15% reduction pulley. Also have a read of this post: Edited by Paul S on 6th Jan, 2008. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
6th Jan, 2008 at 07:07:22pm
When i was browsing around the internet i found some information on the eaton supercharger, i not sure how acurate it is but it said that with the standard bini pulley on it it puts out 11.6 Psi and with the 15% smaller pulley it would be 14.5Psi, does this sound right because i put it into the calculator and it was stating about 154 BHP with the smaller pulley |
591 Posts Member #: 360 Stu from Corwall aka Mr Jazz Piano, Love_Machine, kneegrow |
7th Jan, 2008 at 10:21:56pm
M45's don't like high boosts, but maybe you'd get away with it a tad running suck through, might improve the efficiency of the blower. However, the map doesn't look good for a dP of 12psi when you run it dry. I'm wondering if you could add a bit of ethanol and use the dHv of that to take up a bit of the heat.
Bugger off, I'm getting there. |
7th Jan, 2008 at 10:54:30pm
i was just using the standard one, lol as you can tell i am a little new to this subject
7th Jan, 2008 at 11:38:17pm
Have a look at doing what you're doing but using an avonbar Ph2 cam. It's like a 276 for SC engines. You need the extra exhaust lift/duration in my opinion to run the inlet closure a tiny bit more early, which allows you to get more power. It's been a while since I thought about blower theory a lot but having a high trapping efficiency relies on having a relatively early inlet valve close and enough time to clear everything else. In my opinion, I think the A Series is under exhausted and in order to maximise the engine (with a blower) you have to get everything out as quickly and as totally as possible, whilst minimising overlap yet giving everything a chance to "gasp" properly.
15th Jan, 2008 at 04:19:11pm
Still a little confused, what piston do you turbo guys use under what boost? |
15th Jan, 2008 at 06:05:45pm
How long is a piece of string?
15th Jan, 2008 at 06:19:04pm
is there anyway to calculate what pistons for which boost pressure? for example i posted earlier i read that the bini blower with the 15% reduction would put out about 14.5 Psi so which pistons would i use for this? |
15th Jan, 2008 at 06:32:29pm
There is a graph that was posted which showed the relationship between fuel octain rating, boost pressure and compression. Try searching for "compression ratio" "CR" etc and you will find it. It's a rough guide and dosen't take into acount charge temps etc.
On 7th Nov, 2008 Nic said:
15th Jan, 2008 at 06:56:10pm
this thread is usefull for the compression ratio as there is a handy table to help.
Edited by minimole23 on 15th Jan, 2008. On 7th Oct, 2010 5haneJ said:
15th Jan, 2008 at 07:08:13pm
Try this:
17th Jan, 2008 at 05:19:38am
ok guys i have been looking at all of the infor you have been giving me, and using the blower calculator, if i was to use the JE 18cc pistons, with a drive ratio of 2.18 according to the calculator this would be about 20Psi of boost giving around 180hp is this a unreasonable power out put, is my head in the clouds a little bit? |
![]() 4633 Posts Member #: 20 My sister is so fit I won't show anyone her picture Lake District |
17th Jan, 2008 at 08:21:36am
If you're planning on running 20psi you'll need to uprate more than your pistons, something like 10psi would be a lot more sensible. At that kind of boost a decent set of cast pistons will do the job just fine.
Edited by Turbo Phil on 17th Jan, 2008. |
17th Jan, 2008 at 08:44:14am
I'm with phill on this. Assuming you are planning on using an Eaton M45 (MINI) then at 10 psi you are looking at a minimum temp increase (from ambient) of 65 degrees. There is no info for pressures above 10psi, but it's only going to get a shit load worse.
17th Jan, 2008 at 04:50:54pm
i see well i have just plumed 16Psi into the calcutor and is gives figures of about 170 so that sound pretty good to me. In terms of upgrading the internals what do i need to look at? i think i am going to use the JE 18cc pistons but what else do i need to consider?
17th Jan, 2008 at 05:10:53pm
You can put 16psi into any calculator and have it tell you what you want, but an eaton M45 blowing 16psi will not make that power, no matter what intercooler you use. as stated, they ain't suitable for high boost. I also don't like the idea of running fuel through them as this will ultimately lift the coating off the rotors.
Edited by turbodave16v on 17th Jan, 2008. On 17th Nov, 2014 Tom Fenton said:
17th Jan, 2008 at 06:55:55pm
510 Posts Member #: 1592 Smart Guy! mainland europe near ze germans |
17th Jan, 2008 at 09:04:00pm
http://theoldone.com/articles/damaged%2Dblower/
24th Jan, 2008 at 05:41:46pm
Ok guys can someone surggest the setup i should run for good horsepower output, ie pistons and what psi i should put out of the charger? |
24th Jan, 2008 at 05:46:37pm
24th Jan, 2008 at 06:06:12pm
