| Home > Help Needed / General Tech Chat > nooby head problem | |||||||
19th Jan, 2008 at 05:47:41pm
i am removing the cylinder head off of one of my engines, i have removed all of the head nuts, taken the rocker off all that is left is one sparkplug in and the valves there but i cant seem to get the head off. it moved a very small amount on one side but not the other. i didnt particually want to use a hammer to try and get it free as i dont particually want to damage the head.
19th Jan, 2008 at 05:50:16pm
Have you undone the bypass hose? Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
![]() 514 Posts Member #: 2169 Post Whore Malta (Ex. Scotland) |
19th Jan, 2008 at 06:00:16pm
Give it a tap with a wooden mallet,or hold a piece of wood on the head then hammer on that. Warning:Stig in Training
19th Jan, 2008 at 06:47:23pm
On 19th Jan, 2008 Paul S said:
Have you undone the bypass hose? Absolutely! That's the first mistake. Has it lifted then jamed or is it still tight down? Sometimes it jams on the studs once it's up a bit as the studs spring out or if it's lifted up off-square. On 7th Nov, 2008 Nic said:
19th Jan, 2008 at 07:40:58pm
the front middle stud has a tendancy on the mini to rust up.
19th Jan, 2008 at 08:19:48pm
On 19th Jan, 2008 Sprocket said:
the front middle stud has a tendancy on the mini to rust up. Been there, done that, not fun. http://www.turbominis.co.uk/forums/index.php?p=vt&tid=142775 I hope you have better luck than I did. Isambard Kingdom Brunel said:
![]() 902 Posts Member #: 111 Post Whore Loughborough |
19th Jan, 2008 at 08:48:20pm
a friend onces had a bent head stud. couldn't get the head off or the stud out. had to leaver the head off. |
19th Jan, 2008 at 09:49:38pm
bypass hose??? i dont have any of the water hoses or anything on the head its just the engine in my garage i can take some pics if that helps, i dont belive and of the studs are bent i though it might be like a pressure bild up in stopping the head coming off.... just though of somthing, where its sticking is one end and i still have a plug in there lol oops ill take that off and try if not ill try and leaver it up
![]() 368 Posts Member #: 806 Senior Member Cirencester, Gloucestershire |
19th Jan, 2008 at 10:01:45pm
bypass hose goes directly from the head to the water pump.
19th Jan, 2008 at 10:10:34pm
ah thankyou :) i will have a look its probably that then :$ cheers Drives
19th Jan, 2008 at 10:20:05pm
metro and late mini engine didnt have a bypass hose if this helps.
19th Jan, 2008 at 10:48:46pm
19th Jan, 2008 at 11:06:21pm
On 19th Jan, 2008 Bat said:
Hi, The front center head stud is a slightly larger diameter for some reason, I seem the remember reading somewhere... Cheers, Gavin :) I thought all the studs were the same size, but the front center hole was smaller, I may be wrong though. Isambard Kingdom Brunel said:
20th Jan, 2008 at 12:20:59am
20th Jan, 2008 at 01:01:52am
ill have a boby gander 2moz at it again as far as i know it was a metro engine deff a a+ block Drives
