| Home > Help Needed / General Tech Chat > Clutch Cover Drilling | |||||||
![]() 736 Posts Member #: 1865 Post Whore Norwich, Norfolk |
10th May, 2008 at 10:21:19pm
I have seen a few clutch covers that have been drilled now, like mikes below.
Edited by Simon on 10th May, 2008. |
10th May, 2008 at 10:24:39pm
I dont think it matters tbh, ive seen miglia covers with massive holes. Also i personally wouldnt put mesh behind the holes. 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
![]() 3184 Posts Member #: 628 Post Whore a LIL fishing village on the coast - Newcastle Upon Tyne |
11th May, 2008 at 07:30:53am
dont put anything that shouldnt be in there allready
On 17th Aug, 2009 Jay#2 said:
I doubt I'll be dipping into the 13's like you did though! |
11th May, 2008 at 08:49:07am
the mesh idea was more related to everyday running incase something got in thru the grill and ended up going thru a hole.
11th May, 2008 at 08:53:38am
this has been covered quite well before, try a search "Turbo's make torque, and torque makes fun"
11th May, 2008 at 09:26:07am
well after searching for
11th May, 2008 at 09:33:11am
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=136888
11th May, 2008 at 09:57:22am
psml. i didnt go as large as mike but here is mine
11th May, 2008 at 10:51:51am
search for "10mm spanner"
11th May, 2008 at 11:01:30am
haha "Turbo's make torque, and torque makes fun"
11th May, 2008 at 11:20:11am
After reading through the threads minimole linked, what is the actual point in drilling holes in the cover?
11th May, 2008 at 11:30:50am
the vent above the clutch is for the transfer gears bud, the vents in the wok is just to keep the clutch a little cooler, they can get quite toasty "Turbo's make torque, and torque makes fun"
11th May, 2008 at 11:42:06am
i can see the benifits as per heat and such but has anybody had one that say water or possibly oil form a leaky rocker cover etc etc has got in? can see that being abit annoying |
you dont want bits dropping in there and then being catapulted about the casing by the flywheel. if you are concerned when building it, just pop a cloth over the end casing until you have finnished with all the nut and bolt jobs :)
