Home > Help Needed / General Tech Chat > fans.
Alex1340
Member #: 111
Loughborough
Hi guys,
i'm having a little problem when in traffic which i think a electric fan will sort out. I've got a 2 core rad in the normal place. i have a 4 blade metal fan which works find on the move but not when standing still. Any good cars to find a well fitting fan on? I have heard metro fans fit nice but i have never tried one.
Have people had any joy with ducting the air out like the clubmans used?
cheers
TBH rather than finding one i'd pay the 40 quid for a spal on ebay as it will be thinner and less likly to touch the wheel.
http://cgi.ebay.co.uk/new-RADIATOR-sucker-...1QQcmdZViewItem
I've got a Spal under the wing, nothing else *wink*
Either as above like the guys say, or the carb coopers and the SPI minis had a large fan mounted in the inner wing, you could fit one of these?
Turbo Tel
Member #: 588
Delaware, USA
The combination of the Mk1 shrouding and a decent sized fan in the wing is working well for me
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=196359
I have been out on a couple of 90 degree days and no sign of overheating now, the fan only kicks in during waits at lights and soon switches off once I get moving.
Turbo Rich
Member #: 551
Ashington W.Sussex
I ditched the standard yellow fan and bought a Pacet fan which fits between the side mounted radiator and inner wing without any modifications. I had a slight issue with overheating when stood still for a few minutes until I changed to a 74 deg. stat and now I don't have any problems.
Turbo Tel
Member #: 588
Delaware, USA
I'm using an 82 degree but its a high flow one that flows more when open. Also I run water and water wetter in the summer, i.e no anti freeze.
http://store.summitracing.com/partdetail.a...64&autoview=sku
I always questioned the use of low temp thermostats because they dont actually affect cooling efficiency, just the start point...
The difference being I guess, that for a given temp the lower ones are slightly more open.
As it is I can see where the thermostat regulates to on the guage and when under way thats where it stays...even when the ambient is in the 80's. If I used a lower temp stat the engine would be running too cool most of the time.
Edited by Turbo Tel on 21st Jun, 2008.
