| Home > Help Needed / General Tech Chat > Fabricating my own inlet manifold. | |||||||
976 Posts Member #: 3228 Post Whore North of the Netherlands |
27th Aug, 2008 at 11:57:29am
I replied to another topic concerning inlet manifolds.
Dazed and Confused.... |
27th Aug, 2008 at 12:05:22pm
This is the thread covering my inlet manifold design:
Edited by Paul S on 27th Aug, 2008. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
27th Aug, 2008 at 02:56:17pm
My experience with superchargers may be a bit out of date now,but it used to be recognised practice to use what is called a"log" manifold i.e.two tubes straight in to the inlet ports connected by another tube across their outer ends.The theory was that the sharp turns help to cause turbulence in the airflow and keep the fuel vapourised and the charge more homogeneous (Thats a fancy word for evenly distributed)This probably applies more to suck through systems as they have been more common.Try reading a book by Allard on forced induction or spend an hour or two on research on this site and the net generally -its all out there somewhere |
31st Aug, 2008 at 04:04:25pm
Thanks for answering you my questions guys!
31st Aug, 2008 at 04:17:15pm
31st Aug, 2008 at 04:30:40pm
Hi Gavin,
31st Aug, 2008 at 05:02:27pm
Maybe I shouldn't call it a plenum, it's an inlet manifold.
