| Home > Help Needed / General Tech Chat > adjusting wheelnuts | |||||||
282 Posts Member #: 1404 Senior Member The Netherlands |
28th Dec, 2008 at 02:32:41pm
there is nothing wrong with a A-series that a turbo can't fix.
28th Dec, 2008 at 02:57:56pm
ewwww wobble nuts.....i personally hate them. dont trust them.
28th Dec, 2008 at 02:57:58pm
the thread is a UNF thread, 3/8 UNF iirc.
28th Dec, 2008 at 02:58:31pm
628 Posts Member #: 1064 Formally Whyte_ben Horndean, Hampshire |
28th Dec, 2008 at 03:21:37pm
What are 'wobble nuts' anyway?
28th Dec, 2008 at 03:24:37pm
they are a wheel nut wit a floating washer so you can fit wheels that dots quite have the right bolt pitch, for example....
28th Dec, 2008 at 03:26:15pm
given on minis the only method of centering the wheel is by the nuts, wobble nuts are a big no-no in my eyes! you can get away with it on a modern car that relies on a ridge on the hub to centre the wheel. but not on a mini, those wee studs have there work cut out as it is! turbo 16v k-series 11.9@118.9 :)
28th Dec, 2008 at 03:32:36pm
Damm, they don't fit there is nothing wrong with a A-series that a turbo can't fix.
28th Dec, 2008 at 11:38:56pm
Ah I see, cheers mini13.
28th Dec, 2008 at 11:41:44pm
as evo said, on another forum someone had there wheels balanced repeatedly before realising the imbalance was the wheels werent centralised on the hub itself..
106 Posts Member #: 4636 Advanced Member Uk milton keynes |
29th Dec, 2008 at 05:00:09am
When a wheel passes you! you know its going to hurt!!!
29th Dec, 2008 at 07:10:08pm
a nono to buy there is nothing wrong with a A-series that a turbo can't fix.
29th Dec, 2008 at 09:43:01pm
Nothing wrong with wobble nuts when you use them properly. As said tho, mini=no center location (most of the time)=cant use them. |
