Home > Wanted > intercoolerwanted and pipework
jonboyturbo1
Member #: 4701
south wales, cwmbran
as above cash waiting, wanting intercooler and all pipework for metroturbo engine in mini cheers
flyingturd
Member #: 4008
near cardiff np12
no one will answer it straight forward
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=254735
richminiturbo.
Member #: 719
Horndean - Near Portsmouth
Thats probably because it isnt straight foward, you have to actually think about your own setup and decide how youre going to run it.
It's not hard!! *tongue*
jonboyturbo1
Member #: 4701
i understand wat u mean, just after someones complete setup modified plenhum all pipe work and cooler etc, wat theyve made obviously i want pics to c where they mounted cooler etc,
flyingturd
Member #: 4008
near cardiff np12
ill put what everyone seems to reply with
"hit the search button"
no help really
richminiturbo.
Member #: 719
no help really
Crikey cheer up mate, bad day?
If he did "hit the search button" he might have come across the thread you linked, which is usefull is it not?....
It's entirely dependant on your setup, ie the cooler you want to run and where you want to place it on the car! Theres no rule of the way you route it so its entirely up to your imagination really!!
You can make it as neat or as complicated as you want.
But he's looking for the bits someones already had and running on their car which is fair enough, might be quite tricky though mate, best bet is probably making your own setup!
Edited by richminiturbo. on 30th Dec, 2008.
jonboyturbo1
Member #: 4701
point taken, how do u all get around the plenhum bit?
jonboyturbo1
Member #: 4701
jonboyturbo1
Member #: 4701
jonboyturbo1
Member #: 4701
Dicanio
Member #: 91
Because each persons set up is unique and designed for their car, they don't tend to come up for sale very often, if ever.
There are loads of pics available on here, and it's not that difficult to do.
Just buying someone elses set up may not work anyway, you may have additional stuff under your bonnet such as servo, oil cooler etc.
Mine is like this http://www.turbominis.co.uk/forums/index.php?p=vt&tid=9373
as for plenums. you can get a JF modified plenum:
http://turbominis.co.uk/forums/index.php?p=vt&tid=151665
or a NIC custom one:
http://turbominis.co.uk/forums/index.php?p=vt&tid=9412
