| Home > Help Needed / General Tech Chat > Assembling clutch; is this ok? | |||||||
976 Posts Member #: 3228 Post Whore North of the Netherlands |
12th Jul, 2009 at 08:45:20am
While searching for info I found some people referring to a clutch article in the "how to" section but I was unable to find it...?
Dazed and Confused.... |
12th Jul, 2009 at 09:23:09pm
Is it still 0.8mm if you assemble everything, ie, bolt the diagphram in place and compress the spring and hence "squash" the driven plate ???
13th Jul, 2009 at 11:31:57am
It doesnt look like he has the diaghram bolted on there...so 0.8mm would cause the straps to foul on the flywheel.
Edited by stevieturbo on 13th Jul, 2009. 9.85 @ 145mph
13th Jul, 2009 at 12:28:26pm
No, the diaghragm was not yet bolted on, I thought that wouldn't matter much, maybe 0.1-0.2mm. (?)
13th Jul, 2009 at 12:45:19pm
Yo Han, here were my threads, but remember, I am using a lightened flywheel so thinner, more clearance.....
13th Jul, 2009 at 01:09:00pm
I remember reading the lower link some time ago...
13th Jul, 2009 at 01:38:07pm
!.5mm may still be correct for an orange - the reason for my thread/questions is because I actually measured it before machining, and it came out very close to 1.5mm
18th Jul, 2009 at 09:38:39am
Well, I assembled the clutch, this time with diaphragm and the spring is about flat, maybe 0,1-0,2 mm too far.
