Home > Beginners Tech > fitting (and plumbing in gauges-volts and oil temp) from a mpi dash into an older car
welshdan
Member #: 1111
s wales
hi, my brother has just fitted an mpi dash into his car and wants to get the original dials working.
he has fitted the mini loom to the rear of the clocks, lights etc work. also plugged the time cloch in and this works
does anyone have insructions how to wire up the volts and oil temp gauges?
does the oil clock need some sort of sender, and does anything have to be drilled/tapped on a pre injection block/gearbox to make this fit?
also the revs are over reading on the mpi rev/speedo cluster. is there an adjustment screw inside the rev counter?
many thanks
the volts wants to go one wire to the +ve battery and one too earth if the needle flicks the wrong way switch the wires round
the oil temp well need a sensor you can drill tap the box, some have done the speedo output part as it can be easily removed, or you can get a sandwich plate that goes on before the oil filter and the sender sits in there i think my dads was 13quid or so for his scooby
i think the rev counter error is because the mpi uses coil packs with i think 2 coils? so the dial will be out by 50%? dont know if this can be adjusted easily
Edited by Brett on 13th Oct, 2009.
id attach the volts after the ignition live, otherwise it will show the voltage permanently and it will drain the battery down when your not using the car
as above for everything else, hes right about the mpi clocks going mental, easiest way is to find an old cooper cluster and just stick a set of magnolia dials in them
knew id already looked into this
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=190694
and this one
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=198091
yes that would be a good idea, i did not think it through*happy*
sparkle
Member #: 5544
for the rev counter problem go to :- help needed- instrument panel. i just wrote it up today
welshdan
Member #: 1111
s wales
this was sorted months ago thanks. original post was iin '09. ta
