Home > Show Us Yours! > 1275 N/A Build
dan187
Member #: 6724
Wootton Bassett
Thought i'd share my N/A 1275 that I finished last year. Since then i've been building a 998 turbo (post to come later) and learning lots from TM.
I started off with a lovely 998 racing green edition which i soon found out had been patched up with fiberglass all over the place and had more hidden rust than i thought possible. So flogged the shell, kept all the decent parts to the car and got me a 1275 sprite that someone had given up working on, was in good condition just needed the new front end welding on and a few small fixes.
1275 EFi Turbo
dan187
Member #: 6724
Wootton Bassett
pics didn't attach so i'll link them...
1275 EFi Turbo
dan187
Member #: 6724
Wootton Bassett
Completed shell
1275 EFi Turbo
dan187
Member #: 6724
Wootton Bassett
Got an F1 Ferrari red paint and sprayed the inside but my setup wasn't good enough for a decent finish so had the outside done for me.
1275 EFi Turbo
dan187
Member #: 6724
Wootton Bassett
Work started on the engine. Made some improvements to the ports and chambers. Then made it look all shiny and clean.
1275 EFi Turbo
dan187
Member #: 6724
Wootton Bassett
Then started to put everything together...
1275 EFi Turbo
dan187
Member #: 6724
Wootton Bassett
Here's the car just after his MOT
Was running like crap because i'd changed the cam, put bigger SU on and the head mods but didn't have any other needles so took it to the rollers
1275 EFi Turbo
Looks good,
I like how many mole grips, AND pieces of wood you used to hold the sill on to weld it, I'm just doing my second one now.....
dan187
Member #: 6724
Wootton Bassett
Since then i've made a few changes. Put some nice dished mini lifes on. Adjustable front spax and hi-lo's.
and been on a few track days. Combe and Llandow.
1275 EFi Turbo
MarkGTT
Member #: 1194
Shropshire.
good work, looks super clean.
Nice to see it on the track too.
very nice
like it!! :)
dan187
Member #: 6724
Wootton Bassett
Still a few things to finish it off. I've got some bonnet stripes and i want a badge for the boot because its a bit plain at the mo.
1275 EFi Turbo
nice indeed, did you get any power figures ?
dan187
Member #: 6724
Wootton Bassett
Yeah, just under 70 bhp (can't remember torque, it's on the print out at home. i'll add it when i go back)
Ideally my cam needs timing in tho, I didn't know about it at the time so just lined up the dots.
I've heard that 70 bhp is about right for the setup. I have 1.75inch HIF, kent 266 cam, and ported & flowed head. The rest is standard. It does 0-60 in just under 10 secs
1275 EFi Turbo
thats great dan iam a lover of the 266 kent cam
That's a very nice looking Mini, but with bonnet stripes it will just be another cooper look-a-like like mine.
dan187
Member #: 6724
Wootton Bassett
Yeah I like it, still works well in traffic but just adds some ummph when needed.
Yeah, i did think that. That's why they haven't gone on yet. Perhaps i should get a vote for adding stripes...
1275 EFi Turbo
dan187
Member #: 6724
Wootton Bassett
Just found the print-out from the rollers:
68 lbs/ft @ 3,500 rpm
64 bhp @ 5700rpm (103mph)
looks like I was doing some optimistic rounding when I said 70bhp earlier
Red is before, black is after. Was just after the rebuild so had completely the wrong needle.
Am going on a shoot out next week so will be nice to compare the curves and get a bit of a tune up (I imagine I can't do a direct comparison due to it being a different dyno but should be same ball park)
Edited by dan187 on 2nd Apr, 2010.
1275 EFi Turbo
Looking very nice, good work.
dan187
Member #: 6724
Wootton Bassett
Here are the pics and results of the rolling road in Yate..
Happy with the result. Still pretty much the same as two years ago. Shows a nice flat torque curve so that's good.
When i've got some time i might plot the two different roads on the same scale so i can compare.
Edited by dan187 on 11th Apr, 2010.
1275 EFi Turbo
i really like that
Bman
Member #: 5647
swindon wiltshire
yeh nice results mate..car went really nicely..and not bad figures at all after 2 years since the last RR
